Old 10-29-2012, 12:28 AM   #1
alex1mthrfkr
Drives: Raven Scion FR-S
injen intake problem
Hey guys, I'm new to the forum and I haven't really seen any posts about the injen intake having problems. I purchased one and put it on and I noticed a torque dip on idle and while driving on lower gears. Then after two days, I was going to make a left so the car was in idle and it suddenly turned of on me. (it wasn't my fault) it was like the idle issue, only that it didn't not bounce up again, it turned off. Then when I turned the car on, the check engine light was on. so I went home and took the intake off. Now that I have the stock intake on, my car dosent feel the same... Is it my imagination? Or did I mess something up in my car ( I just hit 7000 miles today)
alex1mthrfkr is offline   Reply With Quote
Old 10-29-2012, 12:40 AM   #2
DAmarcus28
Drives: Scion FR-S
you mentioned the "idle issue" does your currently have that prob? i just had mine reprogrammed by the dealer and its a huge difference, because it would always bounce at idle with the AC on and would almost shut off on me
DAmarcus28 is offline   Reply With Quote
Old 10-29-2012, 12:51 AM   #3
alex1mthrfkr
Only when I turn the car on for the first time it dips once but its not bad so I havnt really cared. But with the intake on, it was bad. Now that the intake is off, it idles like before.
Old 10-29-2012, 02:28 AM   #4
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Mine does the initial idle dip too, but I assumed that was normal.. am I wrong?
RedRocket is offline   Reply With Quote
Old 10-29-2012, 02:49 AM   #5
jstans84
Drives: Scion FR-S
Very odd, I've had my Injen intake on for the past 600 miles and haven't had a single problem with it.
jstans84 is offline   Reply With Quote
The Following User Says Thank You to jstans84 For This Useful Post:
86_Insider (07-23-2013)
Old 10-29-2012, 03:50 AM   #6
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
http://www.ft86club.com/forums/showt...problem&page=2
http://www.ft86club.com/forums/showt...intake+problem
Here's two threads on this issue.. i also have had the same problems.
itsibarra is offline   Reply With Quote
The Following User Says Thank You to itsibarra For This Useful Post:
Old 10-29-2012, 08:44 AM   #7
alex1mthrfkr
Since we both have it, I think its normal
Old 10-29-2012, 08:54 AM   #8
alex1mthrfkr
Here's two threads on this issue.. i also have had the same problems.[/QUOTE]
Yup, that's exactly what happened with mine :/
Old 11-11-2012, 01:29 AM   #9
Realm
Drives: Scion FR-S
Is this a big issue or rare? I just ordered the intake... mine has always had the goofy idle stock... I just don't want to hurt the engine or warranty (does installing this void it? hope not)
Realm is offline   Reply With Quote
Old 11-11-2012, 01:59 AM   #10
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Reset your battery/ecu on any modification, if you have not done so yet. Disconnect the negative terminal for 5 mins and then re-attach.
We have had the Injen on both of our shop FRS cars and had zero issues on 91 octane.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
86design (11-11-2012), 86_Insider (07-23-2013), bear89103 (07-23-2013)
Old 11-15-2012, 10:42 PM   #11
FrsSwag
Drives: Frs,civic
That's dangerous, glad my car doesn't do that. This girl i knows fiesta would do that on the freeway when slowing down for traffic
FrsSwag is offline   Reply With Quote
Old 11-15-2012, 10:56 PM   #12
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Hopefully it works fine after resetting your ECU, but yeah it seems like this intake is a hit or miss for people.
Old 11-15-2012, 11:58 PM   #13
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
I had the same issue... Went back to stock and throttle response returned. Some people had no problem at all though, so I assume that some intakes are defective. I can't imagine it being an inconsistency with the car itself, but I really have no idea.
Be sure to reset your ecu so it can reprogram itself, although some people said it was unecessary as it is always "learning", but I don't know. My car would seem to run better and better with the Injen(after resetting the ecu), start running almost perfect(but never as consistent or responsive as stock), then for some reason it would start to get CEL and idle issues. I have an entire thread of my trials and tribulations(mainly just tribulations, lol), as someone posted above... http://www.ft86club.com/forums/showt...problem&page=2
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 11-16-2012, 12:52 AM   #14
BRZranger
Mine has been working great for about 400 miles on an A/T. Bob @Drift-Office said he has done testing on two different Injen intakes, one showed gains and one caused bogging. He should be coming out with the article in the near future. (Hopefully that wasn't confidential, though its no secret)
BRZranger is offline   Reply With Quote
WTB: Injen intake Obja Engine, Exhaust, Bolt-Ons 3 01-10-2014 09:20 PM
Does anyone in NE have an Injen intake 2forme New England 2 10-28-2012 05:22 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
Injen Intake for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-18-2012 11:54 PM
