Old 12-02-2009, 11:50 PM   #1
USMCMike
Drives: 2003 VW Jetta 1.8t
So what's your real plan for this car?
I know that most of us are already kicking around plans and upgrade paths for the new 86, what are they?
Since I'm going to be stationed around areas with lots of mountains and/or tracks my initial plans are basically as follows:
1: Address seats and cock pit layout.
2: Drop some weight while maintaining an outward appearance of civility.
3: Suspension for track and general higher speed cornering.
4: Wheels/Tire compound
5: Maybe aero, depending on the cars stability and tendencies. (From the Nur videos, she seemed fast but squirrelly.)
At least that's year one. After that I'd be looking at power, and/or seeing how it's working out, roll cage.
USMCMike is offline   Reply With Quote
Old 12-03-2009, 12:04 AM   #2
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
1st: Sport street suspension / TRD suspenion if offered (which it will), sway bars, strut tower braces.
2nd: Short throw shifter and spin-knob for e-brake.
3rd: Tires, IF the ones from factory are subpar. (won't be)
4th: Intake/Exhaust, because my cars gotta be loud. I'll do it shortly after I've had my fill of hearing the engine all by itself for a while.
5th: Clutch/flywheel
6th: Probably wheels.
OldSkoolToys is offline   Reply With Quote
Old 12-03-2009, 12:09 AM   #3
ERA
Drives: .
swap a 2j
ERA is offline   Reply With Quote
Old 12-03-2009, 12:59 AM   #4
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Well that would depend on what rank i am by that point. If all goes to plan and I am at least a WO1 then:
1) Suspension (after i drive the car and see what needs tweaked)
2) Tires
3) I/H/E
Plan to daily this and have a 75 Celica to track, but well see
Ricepuddin is offline   Reply With Quote
Old 12-03-2009, 01:24 AM   #5
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
I'll get the base model cuz, after the warranties are over its fun times
suspension: coilover w/ camber plates, sway bars, strut bars and chassis braces
wheels: TE37 w/ widest but lowest offset i can fit w/ a rolled fenders
stopping power: 6 piston calipers w/ a carbon pad and a slotted rotors
interior: strip down like my AE86 w/ full roll cage, no ac, no heater, no cd played, no speakers, no air bags, full racing bucket seat, lower seat rails, longer wheel hub and deep corn type steering wheel
exterior:what ever aero package TRD will come out with Japan or US, carbon fiber hood and trunk, TRD front & rear spoiler
Engine & differential: turbo, 8lbs flywheel, Kevlar clutch, 2 way LSD and cat back w/o a catalytic converter (nothing with a canister type muffler)
I want it to be like my AE86 but modern
4agze is offline   Reply With Quote
Old 12-03-2009, 09:54 AM   #6
S2KtoFT86
Resident Post Whore
S2KtoFT86's Avatar
Drives: 2022 WR BRZ
Well, as noted in the poll in another thread, mine will be a garage queen. My plans are:
1. Body-Still undecided on full carbon or doing a widebody (hopefully someone reputable releases something)
2. Wheels-Work Meister S1's along with some sticky tires (probably Potenzas)
3. Suspension-Hopefully KW makes some coils for this because that's what I will get and drop it maybe 2"
4. Engine-Turbo, Turbo, Turbo if there isn't a Yota turbo version.
5. Interior-Full custom interior. This will be done at work.
Gavin
S2KtoFT86 is offline   Reply With Quote
Old 12-03-2009, 10:01 AM   #7
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
http://www.ft86club.com/forums/showp...3&postcount=56
-Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 12-03-2009, 12:57 PM   #8
MtnDrvr86
Drives: 2002 honda civic ex
I think initially just some TRD parts depending on quality and if they are in house developed or rebadged aftermarket like current ones. I think it will remain fairly stock for a while. maybe strut and sway bars
MtnDrvr86 is offline   Reply With Quote
Old 12-03-2009, 01:45 PM   #9
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
LSD if it doesn't come with one. Then lightweight rims & good summer tires, stiffer springs (close to stock ride height), struts, sway bars, chassis stiffening where necessary. Then I'm going to put like 3 layers of undercoat on it. I'm not letting it rust like my last 86. Stupid Canadian winters.
I might do intake/exhaust, but nothing that's going to hurt my chances of passing an emissions test.
no_name is offline   Reply With Quote
Old 12-03-2009, 04:16 PM   #10
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
The basics tint out the windows all around, intake and exhuast. Then lower it upgade brakes and cat delete.
Gearbanger is offline   Reply With Quote
Old 12-03-2009, 10:50 PM   #11
cornfed
cornfed's Avatar
Drives: FC3S
Send a message via AIM to cornfed
1. Swaybars hopefully TRD
2. Enkei RPF-1 17"x widest i can fit
3. Good summer tire Kuhmo XS?
4. Sport suspension (TRD) or a GC kit with koni shocks
5. Carbotech XP-8 pads, I like brake dust!
That should make it fun to drive street or track day. I'm pretty excited to see what the aftermarket will do for this car. My Rx-7 hardly has anything bolt on that is any good.
cornfed is offline   Reply With Quote
Old 12-04-2009, 04:26 AM   #12
Blokatos
Drives: MX5 Miata Mk2.5 1.6
1. Removal off waste to lower weight but keep it look like a road car
2. Fit smaller diameter wheels
3. Maybe a shorter (lower) final gear ratio
4. Improve flow on intake and exhaust
5. Sport cat conv.
Hopefully the car will not need much more...
Blokatos is offline   Reply With Quote
Old 12-05-2009, 12:14 PM   #13
ddoouugg
Advanced Member
Drives: RSX
1. TRD SC
2. Sway bars
2.5. Short Throw Shifter
3. Tires
4. CAI
5. What kind of programmable ecu or reflashes will be offered? These determine how far we can mod our engines.
ddoouugg is offline   Reply With Quote
Old 12-05-2009, 12:49 PM   #14
scape
scape's Avatar
Drives: yaris
i highly doubt the tires will be anything REAL good, they'll be decent I suppose. I think toyota can do better on tires, personally; but that is where they have a huge cost savings with deals from tire manufacturers.
here's an email I got back from a bridgestone rep asking them about tire weight differences:
"The Potenza RE92 is an original equipment tire. Therefore, the specs are set according to the vehicle and vehicle manufacturer specs. So, you could possibly have the same size tire with very different or slightly different specs and/or weights."
meaning you could end up replacing your OEM's and have a tire weight difference of multiple lbs, an example: OEM 205/55/15 RE92 is 15 lbs, while OEM 195/55/15 is 19; the non-OEM tire but same model and size 205/55/15? about 19lbs..
why am I writing about all this? the tires you buy your car with, you'll likely never see again, as what is stocked (even the same exact tire brand and model) won't necessarily be what was shipped with your car-- and likely won't last as long as a real tire you buy later.
so with all that said:
1. Tint
2. when my tires bald, and i'm sure it won't be long with my driving hah, new tires at probably at plus size
scape is offline   Reply With Quote
What do you plan to trade in for the FT-86? casualsurfer Scion FR-S / Toyota 86 GT86 General Forum 117 05-27-2014 09:12 PM
