Old 10-23-2012, 08:26 PM   #1
rhysmcinerney
Drives: GT86 Auto
First Mod: 16" vs 17" Tyres for GT86?
Hi Guys,
For my first mod to the car i think i am wanting to get new tyres. To avoid forking out too much at the moment (want to keep it under $800-1000 for the moment) i believe 16" would be the way to go. However ive been told the 17" are exponentially greater than the 16" and will obviously require new rims (thus costing $2k+).
I want tyres that will hold the road considerably and noticeably better that the stock ones (especially when hitting and coming out of corners fast, or accelerating and cornering from a standing position). It is for the aforementioned reason i want better tyres.
What do people recommend? Could i get a great gripping tyre that are 16" and reasonably priced or is it best to save my dollars and invest in 17" which are apparently better than what any 16" tyre could do?
Im located in Australia if this makes a difference when putting forward ideas.
rhysmcinerney is offline   Reply With Quote
Old 10-23-2012, 08:45 PM   #2
sierra
Drives: Skoda Yeti DSG diesel 4x4
I initially ordered a GT and then changed to a GTS, so did a bit of tyre research for the 6.5" x 16" rims. I much prefer the look of your rims just wish they were 8" x 17".
Using the site below you could fit 225/50-16 tyres which have the exact same diameter.
235 is the limit and only makes them 1.6% bigger in diameter but that's pushing it when you look at the pic of the tyre on the rim.
http://www.rimsntires.com/specs.jsp
You could also fit 225/45-16 which would lower the gearing by 3.8%, a good thing on an auto and drop the car 12mm.
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
AbsolutKev86 (04-05-2013)
Old 10-23-2012, 10:21 PM   #3
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
18"
Tansey86 is offline   Reply With Quote
Old 10-23-2012, 10:26 PM   #4
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
Originally Posted by Tansey86 View Post
18"
17"
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 10-23-2012, 10:29 PM   #5
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
Go with the stock size... 17...
RL_BRZ is offline   Reply With Quote
Old 10-23-2012, 10:38 PM   #6
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
The OP's stock size is 16"; he has an 86 GT.
Subie is offline   Reply With Quote
Old 10-23-2012, 10:52 PM   #7
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Originally Posted by rhysmcinerney View Post
Hi Guys,
Grip is a function mostly of tire width, and tire compound. I'm guessing you have the 16x6.5" stock wheels, so your width will be limited unless you get a wider wheel. The stock tire is a 205/55R16. You could probably squeeze a 215 on there, but I wouldn't run anything wider.
Your least expensive choice would be to get a stock-size (or nearly stock-size) tire in a much grippier compound. The Dunlop Direzza Z1 Star Spec is available in a 205/55R16. That's one of my favorite high-performance tires. It's a great value, and has MASSIVE grip. Not so great (okay, completely un-usable) in the cold, but I trust that's not going to be much of an issue where you live.
I would never go that small on the tire diameter. Your speedometer/odometer will be off by the same amount. Plus, it'll look weird.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 10-23-2012, 11:05 PM   #8
Paragon
Guest
Posts: n/a
Hi Guys,
Im in Sydney too, my car arrives in 2 weeks so if you want a new set of OEM 17s then PM me
The Following User Says Thank You to For This Useful Post:
usptwins (10-23-2012)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
Wheel Directory: Rota Torque 17x8.0 +48 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 03-01-2013 12:23 AM
FS [WA] 17" GTS wheels with Tyres x 4 - get a full size spare Z86 Australia Classifieds 3 10-17-2012 04:24 AM
Designing the Toyota GT86 - 4 Part Feature by Toyota Design Chief, "Dezi" Nagaya Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 03-19-2012 12:37 AM
