Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 10-19-2012, 10:40 PM   #1
Z86
Drives: 86 GTS Auto in Pegasus White
Z86 Pegasus White on Kiwamis and Eibach Pro Kit
Its finally done, and DAMN I love it.
Heres my 86, lowered with the Eibach Pro Kit
On Work Emotion Kiwami's 18x8.5 +38 wrapped in Bridgestone RE002's 235/40/18 all round.
(BTW I have 4x17" GTS rims with tyres available for people who want a full size spare - $350 each - pm me)
Enjoy.
Z86 is offline   Reply With Quote
Old 10-20-2012, 03:54 AM   #2
Roadliner
Drives: GT86
Mate, very very nice.
The curves and lines of the 86 just come together when lowered on wider nice alloys. The best colour of course
Still waiting on mine,
Roadliner is offline   Reply With Quote
Old 10-20-2012, 05:01 AM   #3
rosco186
Drives: Ordered Pearl White GT 86 Manual
looks sgoooooddd! did you need camber bolts with the springs?
rosco186 is offline   Reply With Quote
Old 10-20-2012, 05:09 AM   #4
omgwtfbbqsauce
omgwtfbbqsauce's Avatar
how does the ride comfort compare to stock springs?
omgwtfbbqsauce is offline   Reply With Quote
Old 10-20-2012, 08:26 AM   #5
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
excellent! i have this same combo except i went with 9.5 all round and wont be running centre caps. i'll probably put coilovers in too as id like it a little lower than what the eibach springs offer.
spiller is offline   Reply With Quote
Old 10-20-2012, 08:32 AM   #6
Z86
No, my suspension guy said he'd put em in if needed but it wasn't.
I prefer it. It feels more grounded yet maybe only slightly stiffer. These are the US springs - apparently Australia will be getting the German spec'd ones and they are stiffer again.
This is my daily driver and I drive a lot for work, so comfort was important.
Old 10-20-2012, 08:58 AM   #7
70NYD
70NYD's Avatar
Drives: RX8 S1
Very, very nice
Very tasteful and thank you for no flush/poke
You should have good handling with that setup as well (not overly wide, tire suits rim width ie no ridiculous stretch )
70NYD is offline   Reply With Quote
Old 10-20-2012, 09:57 AM   #8
ZZT86
ZZT86's Avatar
Drives: BR86
Looks superb, Perfect even ! What was the ride drop? How does the car's handling & ride compare to factory setup ? What's the car like on those grippy tyres? Is the cars alignment within factory spec or out ? Expensive ? Cheers - great job !
ZZT86 is offline   Reply With Quote
Old 10-20-2012, 05:49 PM   #9
Nardi330
Nardi330's Avatar
Drives: 86
Looks good. Looks like ground clearance is still good for DD.
Nardi330 is offline   Reply With Quote
Old 10-20-2012, 07:13 PM   #10
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Looks gorgeous buddy!
you and I might end up being twins :3
do you find that it becomes a bit floaty with the bigger wheels?
Surok is offline   Reply With Quote
Old 10-20-2012, 08:25 PM   #11
kvl
kvl's Avatar
Drives: 86, A1
Looking good, I'm having same white on blk work wheels except using sportline instead of pro kit !
kvl is offline   Reply With Quote
Old 10-20-2012, 09:14 PM   #12
nix
nix's Avatar
Drives: AVO BRZ
Looks amazing but hmm @ the beat sonic fin. I dunno if I will put mine on now.
nix is offline   Reply With Quote
Old 10-20-2012, 11:33 PM   #13
Z86
The ride height change was actually pretty minimal - because the rolling diameter of the wheel/tyre combo was about 20mm more (and surprisingly I could feel that it was higher before the springs went on) I gained about 10mm clearance, and so the springs which dropped it about 25mm, means that my actual clearance change was only 15mm lower
Just measured it - clearance is 115mm under the engine pan (lowest point). The front lip clearance is 145mm.
The sportline would have been too low for me (as it is I have to mount my driveway carefully due to the large slope).
It is a bit more grippy - but I always felt it wasn't grippy enough before - I would get wheelspin just pulling out of my street without trying hard. I can make it spin and slide now, but by choice. I'm sure when I get it on the track I'm going to love it.
I must've left the alignment specs at work - but for memory it was within spec.
Expensive? All relative - but I thought the fitting for springs was a bit pricy - came in at $550 including full alignment (not including springs which I supplied)
Not at all.
Old 10-21-2012, 06:47 AM   #14
ZZT86
ZZT86's Avatar
Drives: BR86
Gee, the thought didn't even cross my mind yester but that extra 20mm RD is gonna screw your speedo accuracy. It looks magnificent tho !
FS: Work Kiwamis and Eibach Pro-Kit Z86 Australia Classifieds 0 10-08-2012 09:47 PM
SWAP: Toyota 86 GTS 6MT Tornado Grey for GTS 6MT Pegasus white john_jre Australia Classifieds 4 08-02-2012 01:26 AM
Pegasus White 86 Tinted and Tough Sealed Z86 AUSTRALIA 18 07-20-2012 05:57 PM
My 86 GTS Pegasus White Manual! DriftEightSix AUSTRALIA 38 07-07-2012 06:36 AM
Pegasus White? autogyro AUSTRALIA 5 05-07-2012 07:30 AM
