Hot fuses?
After searching I found a few answers but I'm looking for extensive info on the following:
Anyone have a list of "hot" fuses and "ignition on-hot" fuses? I am figuring out where to tap in my backup camera for ignition-on. |
Drives: 2012 FUJI Z
Anything engine related will be hot on ignition, most entry/security items will be always on.
| The Following User Says Thank You to CMOS For This Useful Post: | BRZranger (10-10-2012) |
Drives: 2013 Subaru BRZ
For the Backup camera I tapped the B+ wire behind the radio, you could also use either of the cig lighter sockets. I would recommend B+ for this if you are using the factory radio, when I did mine I ran into issues with the radio booting up and not seeing the camera was on and then blocking out the input signal so it would not work until you turn the car off and on again. Ignition should still work but I know for a fact that B+ works perfectly.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
| The Following User Says Thank You to Flat Black VW For This Useful Post: | BRZranger (10-11-2012) |
