Old 10-08-2012, 10:17 AM   #1
Hamza7
Drives: MiniVan
What is Opti Coat?
Why this treatment would appeal to you.
-You like a clean vehicle but don't have the time, interest or knowledge maintaining it.
-Living circumstances make it difficult maintaing your vehicle. Ie. Condo, no driveway, or living in dormitory
- You like having extra protection (2 micron buffer)
Opti-Coat is a hard wearing, aftermarket, ceramic clear coat for superior resistance to scratching (9H) and chemical etching from environmental impacts.
How Does Opti-Coat Protect the Factory paint?
A single layer of Optimum clear coat measures approximately 2 microns in thickness. Compared to other "paint protection" sealants, Opti-Coat is more than 100 times thicker with tests showing a wax coating measuring less than 0.02 microns.
This allows Opti-Coat to effectively absorb damage that would otherwise affect the factory paint layers. Swirl marks, light scratches, chemical etching is not only decreased by the harder clear coating, but the factory paint is protected by the thick outer Optimum coating.
The Optimum Coating is also resistant to acidic substances such as bird droppings. Unlike your factory clear coat that can be permanently damaged, Opti-Coat will not etch or dissolve when in contact with these acidic substances and a clean, glossy clear coating is maintained.
How Is Opti-Coat different to other paint protection/sealants?
Opti-Coat is not a wax or sealant like other products on the market. It is a ceramic clear coating very similar to factory type clear coats.
A layer of Opti-Coat measures approx. 2 microns in thickness, or about 100 times thicker than your typical wax or sealant. Unlike paint protection sealants such as PTFE, Nano Sealants, GlassPlexin that degrade over time and are easily removed through washing with water or chemicals, Opti-Coat does not degrade and cannot be removed by chemicals such as heavy duty truck washs or even caustic degreasers. It is totally resistant to these chemicals and produces a permanent film that is chemically bonded with the factory paint layers.
Opti-Coat is effectively the vehicles new outer clear coat. It is far more resistant to chemical etching than factory clear coats and far more resistant than competing paint protection sealants. The 2 micron layer also provides a thick buffer between any damage and the factory paintwork.
What are the benefits of applying Opti-Coat to my car?
Opti-Coat will provide the owner with a superior clear coat film that is highly resistant to chemical etching, harder than factory clear coat to reduce swirls and scratches, and a permanent hydrophobic surface that is easier to clean and stays cleaner for longer.
Things that can deteriorate or destroy the coating
- Abrasion IE. trading paint with other cars, polishing, wet sanding, repainting, harsh rubbing of any sort
Hamza7 is offline
Old 10-08-2012, 10:17 AM   #2
Hamza7
Drives: MiniVan
List of Preferred Paint Reconditioners offering this service.
Canada
Southern Ontario
Hamza N. @ Elevated Car Care. hamza@getdetailed.ca. We use Opti Guard.
BC
Ken Wilson @ Autowekes Exclusive. Please Call 604.561.5121 for more information.
Alberta
-Edmonton. Troy @ Auto Obsessed. AutoObsessed.com for more information
-Calgary. Please see Calgary members about Carlos
Saskatchewan
Deluxe Auto Detailing. http://www.deluxedetailing.ca/ for more information.
U.S.A
NY & NJ
Greg @ http://signaturedetailing.com/. Please Call 973-886-1306 for more information.
SoCal
Tuan @ http://glossworksla.com/. Please Call (626)675-9350 for more information.
South Carolina
Forum member MikeNap for more information.
GA
Mike @ http://www.mirrordetailing.com/. Please call (770) 354-7010 for more information
Tennessee
Corey J @ As Clean as it Gets Auto Detail. Please call 865-323-4234 for more information
PA
Josh @ OC Detailing. 406 Little John Drive, Dillsburg. Serving Harrisburg with Available Mobile Service
Hamza7 is offline
Old 10-08-2012, 10:32 AM   #3
JDMenrique
DEEEERP
JDMenrique's Avatar
thanks for the write up
JDMenrique is offline
Old 10-20-2012, 09:30 AM   #4
RONIN8
The links for USA don't seem to be working. Nice write up. Any techs by Las Vegas or will be in town for SEMA? Thanks
RONIN8 is offline
Old 10-20-2012, 04:30 PM   #5
ReflectiveAuto
Drives: Acura RDX
Opti Coat is the consumer product and Opti Guard is the professional product.
ReflectiveAuto is offline
Old 11-12-2012, 11:43 PM   #6
EDCOVEY
Drives: Firestorm Red FR-S
I accidentally got some Opti Coat on one of my windows. Any advice on how to remove it?
EDCOVEY is offline
Old 11-13-2012, 12:02 AM   #7
mach330
Drives: Ultramarine frs
So how long does opti coat last?
Tap'd from my G-Nex
mach330 is offline
Old 11-13-2012, 12:06 AM   #8
cnk
Drives: '13 DGM BRZ Limited
You can actually apply it to windows if you want, the OC 2.0 stuff at least. If you want to remove it, just polish it off. Same process as if you want to remove it from paint.
cnk is offline
Old 11-13-2012, 07:11 AM   #9
Hamza7
Drives: MiniVan
Tap'd from my G-Nex
A Long Long Time, up to 5 years. I recommend you go back to your installer every three years to have it redone so that you have a bit of leeway on your paint.
Hamza7 is offline
Old 11-13-2012, 08:06 AM   #10
2forme
Please Unique Auto Care in Wakefield, MA to the list. @Rickrack did my car as well as @Sony's car and the work was impeccable. My car still shines like new with not a swirl mark on it.
2forme is offline
Old 11-14-2012, 10:38 AM   #11
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I second Rick he freakin rocks!
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline
Old 11-14-2012, 11:28 AM   #12
Blypr
Drives: 2013 Asphalt Scion FR-S
Anyone know of a place in NC that does this?
Blypr is offline
Old 11-14-2012, 02:18 PM   #13
Hamza7
Drives: MiniVan
I actually put MikeNap as SC, he's in North Carolina. PM mikenap
Using tapatalk.
Hamza7 is offline
Old 11-14-2012, 11:14 PM   #14
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Very interested in doing an opti-guard for maximum protection.. I can't really give my car regular car washes where I live. Do you know of any good shops that do it in the SF bay area?
Also, if I plan on adding some aero stuff (body kit, spoiler), do you recommend waiting until I finishing adding on everything to do the optiguard or do the optiguard before the adding anything so none of my OEM paint is covered by the aero stuff?
cdo221 is offline
Opti-guard / Opti-coat detailers in Richmond? xjohnx Mid-Atlantic 10 02-05-2013 10:33 AM
Opti-Coat / Opti Guard Near Ann Arbor, MI Brzce Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 09-18-2012 03:12 PM
Difference between Opti-Coat and Opti-Guard? davey90 AUSTRALIA 34 08-20-2012 10:26 AM
Why Opti-Coat your Car? Hamza7 Cleaning and Detailing 234 07-30-2012 10:13 PM
Opti coat near me Nate219BRZ Cosmetic Modification (Interior/Exterior/Lighting) 7 07-20-2012 08:24 PM
