Old 09-26-2012, 05:01 PM   #1
NOHOME
Drives: RAVEN
Steelies for Winter Tires
Hello everyone. Been lurking a while, driving my car since June and figured it was time to chime in...
Need to swap out to Blizzack snow tires in a few months. Figured Tire Rack would set me up no problems. WRONG! Seems they do not have any steel wheel options for the FRS.
Are the rims unique to this car?
Called the dealer and they have not heard of any steel rims either.
What are others doing for this?
I've not been a fan of Alloys for winter due to corrosion and snow packing leading to unbalanced wheels.
NOHOME is offline   Reply With Quote
Old 09-26-2012, 05:03 PM   #2
TuxedoCartman
Drives: '13 86
Well, I know the base model 86 comes with steelies in Japan, although that might be stupidly expensive to import.
TuxedoCartman is offline   Reply With Quote
Old 09-26-2012, 05:04 PM   #3
cnk
Drives: '13 DGM BRZ Limited
They should have 16" steelies available. I priced out a set earlier, but I'm leaning towards just getting some Rota Grids or Motegi SP10 rims for winter just because I don't like the looks of steelies and our winters aren't too bad. May have to set your car as a BRZ though if it's not showing up as an FR-S. Probably just a DB glitch where they haven't associated the 2 cars.
cnk is offline   Reply With Quote
Old 09-26-2012, 05:06 PM   #4
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
The bolt pattern and offset seems to be fairly common on Subaru vehicles. Perhaps a scrap yard Impreza would be a good donor? You would have to check to see what the offsets are for various Subaru models and years.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 09-26-2012, 05:45 PM   #5
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I just went to Tire Rack's website and it took me about 30 seconds to find steel winter wheels. 16x6.5, $58 each. I looked under BRZ-> winter -> wheels. They appear to be the exact same ones I bought for our Forester a couple of years ago.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 09-26-2012, 06:06 PM   #6
NOHOME
Drives: RAVEN
This was the suggestion from the Tire Rack tech. I would have ordered if I knew for a fact that the 16" rims would go on the car. I assume they are hub-centric as required.
I expect that this will be the way to go since next option is $150/wheel
Now I just need to confirm that if I dont run TPS the traction control will still turn off when I want it to, or I will be stuck in a lot of snow drifts.
Thanks.
Old 09-26-2012, 06:13 PM   #7
Miniata
Thanks.
Traction control and stability control work the same whether or not you have TPMS installed in the new wheels/tires. My summmer/autocross wheel/tire setup does not have TPMS, the light is on all the time, and everything works the same as when it had the stock wheels/tires on with TPMS.
edit: hubcentric wheels aren't required, but they do give a lot of people some extra peace of mind. Anyways, I went out in my garage and measured the hub bore of the 16x6.5 5x100 steelies I got for our Forester from Tire Rack a few years back, and I measured the hub bore of the stock wheels, and it is the same, so the Tire Rack steelies are hubcentric, at least in this application
Winter tires jesseps CANADA 83 12-13-2016 05:06 PM
Winter tires...? baadshah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-28-2012 01:29 PM
Winter tires si CANADA 30 08-26-2012 12:07 PM
Winter tires lookout Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-09-2012 04:00 PM
Winter steelies whtchocla7e Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-29-2012 10:21 AM
