Old 09-19-2012, 03:19 PM   #1
DetailersDomain
DetailersDomain's Avatar
Drives: Audi S4
Have a detailing question - Ask Detailer's Domain
Let me know what's on your mind, how to apply something, tech questions on detailing?
I will try to answer it the best I can also welcome others to answer as well.
A great instructional video for newbies and veterans alike.
Adam's Instructional Videos
Updated - How to navigate - Detailer's Domain
Take a look you can do quite a bit on our site
Like Us on Facebook.
DetailersDomain is offline   Reply With Quote
Old 09-20-2012, 08:44 AM   #2
DetailersDomain
Drives: Audi S4
FRS - New Car Prep - Opti-Coat - Clear Film Installation - White Out
FRS - New Car Prep - Opti-Coat - Clear Film Installation - Raven
FRS - New Car Prep - Opti-Coat - White Out
BRZ - New Car Prep - Opti-Coat - Clear Film Installation - WRB
BRZ - New Car Prep - Opti-Coat - Galaxy Blue Silica
BRZ - New Car Prep - Opti Coat - Black Silica
Old 09-30-2012, 06:45 PM   #3
Skye
Drives: TR2,CooperS,BRZ
I don't know if this question belongs under detailing, has anyone a comment on undercoating and whether or not it will reduce wind/road noise? If so what kind?
Skye is offline   Reply With Quote
Old 10-01-2012, 10:26 AM   #4
DetailersDomain
Drives: Audi S4
sorry I won't be able to answer that one for you.
Old 10-01-2012, 10:39 AM   #5
#87
I usually post drunk
#87's Avatar
There are plenty of write ups on rinseless washes but is there anyway to properly wash wheels without running water?
I presume the obvious answer is to use the same procedure on wheels as paint, but I find the brake dust is more abundant and harder to clean than body dirt and the best way I've found is soap and running water
#87 is offline   Reply With Quote
Old 10-01-2012, 10:56 AM   #6
DetailersDomain
Drives: Audi S4
sure on a lightly dusted wheel I would use a towel and some detail spray,
but if they are heavily caked on I would suggest you go with a good wheel cleaner and brushes and running water.
Sonax Full Effect Wheel Cleaner
Wheel Woolies
Old 11-04-2012, 03:30 PM   #7
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Waxed the new car. how many times in a year should you wax the car? I'm using synthetic wax. do you need to removed old wax if reapplying wax? Thanks!
tintumz22 is offline   Reply With Quote
Old 11-04-2012, 03:40 PM   #8
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Dealer messed my clearcoat up bad. Has lots of swirls and clearcoat scratches. What's thr best approach to correcting? Don't want to use fillers as those will just wash away.. looking for a more permanent solution thanks
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 11-04-2012, 05:55 PM   #9
Tylub
Tylub's Avatar
Originally Posted by ReflectiveAuto View Post
There is no Permanent solution...are you going to do the paint correction yourself or are you looking for a proper detailer that can fix your paints problems?
Best way to do it, after decontaminating the paint is to use a top quality compound (1 Step or 2 Step) to remove the scratches and swils (RIDS) and follow up with a top quality polish, with a DA and a proper foam pad for that job at hand, then top that with a quality wax or sealant.
myself, as i don't trust anyone else. "if you want something done right, do it yourself" right?
thanks, i guess i just have to repeat this step every couple of months ehh?
instagram @Tylub
Old 11-05-2012, 12:52 PM   #10
DetailersDomain
Drives: Audi S4
sorry for the delay no power due to Sandy.
as for how many times a year some do it once a month, some wax after every oil change.
there is no set rule.
you will only need to remove the wax if you want to change the type of wax you are using or want a fresh start.
Old 11-05-2012, 12:54 PM   #11
DetailersDomain
Drives: Audi S4
what machine are you planning to use?
Old 11-05-2012, 01:30 PM   #12
Tylub
Tylub's Avatar
I'm probably going to go with the Maguiar's ultimate compound and the orbital buffer. But before i start i'm going with mother's clay to clean everything off. The dealer "detailed" my car as a solution to the fix and ended up doing a really bad job and just sealed in a bunch of debris and marks... then i'll finish up with some paste wax
hopefully that should suffice
what do you think?
instagram @Tylub
Old 11-05-2012, 01:30 PM   #13
Tylub
Tylub's Avatar
and hope you guys are ok
instagram @Tylub
Old 11-05-2012, 02:23 PM   #14
tintumz22
tintumz22's Avatar
N problem and I'm sorry to hear about Storm Sandy. Fast recovery for y'all there. What to use in stripping off the wax?
detailersdomain, detailing product, paint correction
Detailer's Domain: Brings this one back to life - 05 Mercedes SL55 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 09-01-2012 04:02 PM
Detailer's Domain: Scion FRS - New Car Prep and Opti Coat DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 08-23-2012 08:46 AM
Detailer's Domain: FRS - New Car Prep, Opti Coat, and Clear Film DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 08-14-2012 08:03 AM
Problems with detailing Nezz AUSTRALIA 23 06-28-2012 09:08 AM
BMW X3 Detailing 101 OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 06-20-2012 04:40 AM
