Old 09-12-2012, 07:36 PM   #1
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Installation cost for a crank pulley?
I'm a noob when it comes to installing aftermarket items, so I'd rather leave it to the experts. Is 70$ a reasonable price for the labor? It seems fast and easy to install from the tutorials...
Readytoxplod is offline   Reply With Quote
Old 09-12-2012, 07:36 PM   #2
2forme
I wouldn't pay more than 15$, and even then, that's a dollar a minute.
Old 09-12-2012, 07:38 PM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Yes, and no. It's a really quick and easy job, but the simple fact is whenever you have someone else do the work ther is going to be a minimum charge which this probably falls under.
Old 09-12-2012, 07:44 PM   #4
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
A lot of shops have a 1 hour minimum and $70/hr seems to be a fairly average rate. Seems decent to me.
-Zach
RallySport Direct is offline   Reply With Quote
Old 09-12-2012, 07:50 PM   #5
W2
W2's Avatar
Drives: Firestorm FR-S
If you are planning to add aftermarket parts to your car you better learn to do the work yourself or it will get insanely costly. You need to start somewhere and the pulley is stupid easy, check the DIY section as I am pretty sure there is a write up.
W2 is offline   Reply With Quote
Old 09-12-2012, 07:53 PM   #6
Celica00
Celica00's Avatar
Drives: 86
find someone in your area who has done the mod. if i lived nearby id do it for ya for just 10 bucks or free food or something. i'm sure someone in your area would do the same.
Celica00 is offline   Reply With Quote
Old 09-12-2012, 08:28 PM   #7
JohnATL
JohnATL's Avatar
Drives: 2013 Scion FR-S MT Raven
If you don't have the tools (Breaker bar, torque wrench, sockets and screw drivers) then buying these to do it yourself can easily run more than $70. If you plan to do other aftermarket stuff it's worth the investment to get your own tools and learn your car. Take the opportunity to learn and enjoy it.
JohnATL is offline   Reply With Quote
Old 09-12-2012, 08:38 PM   #8
mike2100
mike2100's Avatar
Drives: 23 BRZ
Just don't do it without a torque wrench, please.
I'd do it for a beer.
mike2100 is offline   Reply With Quote
Old 09-12-2012, 08:40 PM   #9
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
This is so true. A few years ago i invested in a basic socket set, torque wrench, air compressor, impact gun, and impact sockets. Also got a spring compressor, and a few other odd tools etc. Total spent was about $300. Then i installed pulleys, intake, exhaust, suspension, brake pads/rotors. Within a year the tools paid for themselves, probably 3 times over. Shop labour is rediculous, and with all the online resources and DIY's it's really hard to mess something up. Always just give yourself 2-3x however long the job is supposed to take... take your time, and have fun! Its very satisfying when you do the work yourself .
Ravenlokk is offline   Reply With Quote
Old 09-12-2012, 10:47 PM   #10
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
If its an auto I would recommend a shop doing it for you as its not easy to get it off (you need to lock the flex plate) if its stick its not too bad. We charge about 50 for the install and free if you buy the pulley from us.
PrimeMotoring is offline   Reply With Quote
Old 09-12-2012, 11:37 PM   #11
RallySport Direct
Now that's a deal!
Thanks,
Rick
Old 09-13-2012, 03:45 AM   #12
Opposed
Drives: 2013 Asphalt FR-S
Man, I was lucky enough to get it done for free from a local shop right down the road from my house. But yes, I really took about 15-20 minutes, so I don't see it costing too much.
Opposed is offline   Reply With Quote
Old 09-13-2012, 08:04 AM   #13
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I am not mechanically inclined. Never even did an oil change. I installed my pulley no problem.
It built some confidence in me for sure. I'm looking forward to installing more mods.
I'd rather do the mechanical stuff than electrical.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 09-13-2012, 08:34 AM   #14
neutron256
neutron256's Avatar
You can also use a crank pulley tool. That's what I did, and it makes the job easier on a MT as well. Well worth the $50 I paid for the tool.
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Perrin/Brand 'Y' Crank Pulley ? rikdrt1 Engine, Exhaust, Transmission 1 09-10-2012 04:39 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
