Old 09-06-2012, 11:06 AM   #1
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
TE37: +45 more convace than +40???
Hey,
I have a question for the wheel experts, I'm looking to purchase a set of TE37 in 18x9.5, but not sure about the offset.
From the pics I see, the +45 offset seem to be more concave then +40 offsets, but from what I understand the lower the offset, the more concavity there should be. From the pic below, the +40 offset seems like it's a flat face.
18x9.5 +45 all around:
18x9.5 +40:
Can anyone explain this?
Thanks,
Shu
shu5892001 is offline   Reply With Quote
Old 09-06-2012, 11:24 AM   #2
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
Yes, those are different types of TE37's. The Concave versions are newer, I think they are called SL's. Can anyone confirm? The bottom ones are just normal TE37's.
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Old 09-06-2012, 11:27 AM   #3
camelflage
Drives: pinto power
correct, SL faces are more concave..
camelflage is offline   Reply With Quote
Old 09-06-2012, 11:37 AM   #4
shu5892001
Ontario's FT86
I see some sponsors sell TE37SL in 18x9.5 +40, so I should expect the +40 offset be more concave than +45 given they are all SLs?
Old 09-06-2012, 11:42 AM   #5
jkonquer
Drives: 2005 Subaru STI
I believe there are different faces volk wheels. There are ones that are flat looking and more concave. Mainly for clearing the bbk.
jkonquer is offline   Reply With Quote
Old 09-06-2012, 11:50 AM   #6
Jade 86
Jade 86's Avatar
Drives: EVO X & FRS
The 18x9.5 +40 5x100 has the same concave, Rays made that spec for Mackin Industries to sell to the US Market.
Jade 86 is offline   Reply With Quote
Old 09-06-2012, 01:33 PM   #7
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
The TE37 Super Lap 18x9.5 +45 5x100 is concaved, also available in 17", its made for the BRZ/86, the regular TE37 is flat until you go 9.5 offset 28+ or 9.0 +22 but its only in 5x114.3 pcd
adprokid is offline   Reply With Quote
Old 09-06-2012, 01:52 PM   #8
RAYSSPL
Drives: bicycle
Concavity is not only dependent on offset, but width as well. Backpad thickness matters too.
RAYSSPL is offline   Reply With Quote
Old 09-06-2012, 02:44 PM   #9
camelflage
Drives: pinto power
DISCLAIMER: THIS IS GENERAL INFORMATION, IF MACKIN DECIDED TO MAKE A NEW MOLD FOR EVERY SINGLE OFFSET THEN WHOOP-DEE-DO, I STAND CORRECTED, BUT THIS IS HOW IT USUALLY TURNS OUT FOR HIGH-VOLUME WHEEL MANUFACTURERS
not necessarily. a wheel manufacturer will usually make molds for only a few faces at each diameter. then they will use those faces for a range of offsets, adjusting the backspacing to fine-tune the offset throughout the range.
basic example: 18" diameter wheel
8.5 width with a HIGH offset gets face 1 (flat)
8.5 width with a LOW offset gets face 2 (barely concave)
9.5 width with a HIGH offset gets face 2
9.5 width with a LOW offset gets face 3 (concave)
and so on...
so an 8.5 wheel with a +40 offset and an 8.5 wheel with a +45 offset would use the same face, they just mill an extra 5mm off the mounting surface to adjust between +40 and +45..
so for your situation, it is doubtful to me that volk would make a completely new face for the 5mm difference between +40 and +45 at the same width.
Old 09-06-2012, 03:05 PM   #10
shu5892001
Ontario's FT86
and so on...
OK Thanks, that explains it
Old 09-07-2012, 04:19 PM   #11
RavSpec
Drives: Rx7
From what I was told ..
18x9.5 +40 TE37SL 5x100 made for BRZ / FRS will be using the 18x9.5 +22 mold which are the more concave one.
The front will be 18x8.5 +35 and the rear will be 18x9.5 +40
That's ur only option as of now. 18x8.5 +35 will be flat face.
Although they do make other offset, but only in 5x114.3
Shu5892001 / please ignore the PM i sent you.
Basically TE37SL options are
18x8.5 +33 or 18x9.5 +40
NOTE: 18x9.5 +40 will clear STI brembo caliper in the front.
RavSpec is offline   Reply With Quote
Old 09-09-2012, 08:49 AM   #12
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
These are sizes of TE37 SuperLap for the BRZ,FR-S and 86.
Old 03-01-2013, 12:33 PM   #13
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
Where can THESE te37 SL's be found/distributed (w/ these size/bolt specs)?I have a hard time locating... and do they require the use of any spacers are you aware of? Thanks
FullTuneZN6 is offline   Reply With Quote
Old 03-01-2013, 01:38 PM   #14
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
You can try us. We are one of the Volk Racing distributor.
The bad thing about Volk Racing, they only tell you on paper about the offset and the amount of concave so I have to spend a lot of time to find out
here's the pic of 18x9.5 +40 that we recently sold !
AJ PwR is offline   Reply With Quote
Volk Racing TE37 thread quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 364 04-01-2024 07:43 AM
Wheel Directory: Volk TE37 17x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-11-2016 03:49 AM
FS/FT: 17x8 +35 TE37 Bronze bAS1c Wheels and Tires 17 05-02-2014 11:52 AM
Wheel Directory: Volk Racing TE37 17x8.0 +44 Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 09-19-2013 09:28 PM
TE37 Seibon Editions vividracing Wheels and Tires 25 11-02-2012 07:38 PM
