Drives: frs
Valve shim clearances
Hey guys, I just need some help. I just got a quick question so I’m in the process of setting the clearances on the valve shims right that sit right under the rockers at the tip of the valves. So I set all my clearances to the right specs and then I set the timing on the motor and then cranked it about 2 to 3 times went back to check the clearances and then they were all off. Anybody else have this issue and then how to resolve this?
| Understanding Subaru Valve Lash "Shim" Numbering? | hotrod1442 | Engine, Exhaust, Transmission | 3 | 01-29-2026 05:44 PM |
| Valve clearances on built block | jrhudson | Engine, Exhaust, Transmission | 11 | 08-12-2021 02:36 PM |
| BRZ Lip Kit Clearances | FRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-09-2017 01:07 AM |
| Does anyone have a complete valve shim kit that I can rent or borrow? | D K | Engine, Exhaust, Transmission | 0 | 04-13-2015 02:42 PM |
| Valve shim confusion.. | Hempo | Engine, Exhaust, Transmission | 0 | 02-16-2015 04:45 AM |
