Old 03-07-2026, 10:42 AM   #1
InstaGib
Drives: 2015 Scion FR-S || Raven Black
Curtain Airbag Removal/Delete
Hi All -
How can I remove the curtain airbags (the airbag spanning from the C-pillar over the doors into the A-pillar) in a way that does not throw a light on the dash or OBD-II code?
I'm taking another step towards dedicated track build, and I'm running into some issues while preparing for safety install. I'm opting for a custom weld-in half cage, and am currently removing everything that might be in my fabricators way. This looks to include the curtain airbag. From what I'm seeing, it will prevent us from getting the main hoop as tucked to the roofline as possible and also interfere with the airbag in the event of a deployment anyhow.
I've seen plenty of guides on doing a similar task for the seat and steering wheel airbags, which I will also be doing. My main concern here is that for at least the next year or two I'd like to keep the car registered on the street, to make getting to/from local events easier. Therefore I need to keep any dash lights at bay. I've considered just pulling the SRS module, but I'm sure that would put a litany of codes into the main ECU.
Thanks in advance for any input, I've tried searching the forums/youtube/Reddit and just had no luck so far
InstaGib is offline   Reply With Quote
Old 03-07-2026, 09:02 PM   #2
InstaGib
Okay, I figured it out through some research, some guessing, and some can-do attitude.
For anyone that may be needing a similar solution, here's what I came up with:
From various sources, it seems like 2.2Ω - 3.3Ω is the sweet spot for fooling the airbag module. In the front seat this is rather straight forward - just shove the legs of a resistor in the plug. For the curtain airbags though, this is a bit more complicated. The plug the side/curtain airbags use is different, and has a substantially bigger hole in it for each prong of the male plug. By using various stud earrings that were around the house, I determined that each prong in this plug takes an 18ga conductor. The resistor alone will not work, it just rattles around and doesn't make consistent contact.
So with this info, what do we do? Well, there's actually a quite nice off-the-shelf solution made by Ling-Labs that I found ( Link Here ). To be clear - I did not use this, and have no history or experience with this brand. At $20/pc (you'll need 2, so it looks like $18/pc currently) it's a bit steep, but honestly I really like their solution. I unfortunately am in a time crunch and can't wait for shipping, but I had planned on making a similar solution myself in CAD and printing it. That is, until the extruder on my printer exploded. So that experiment will need to wait until I get the printer patched back together. Stay tuned I suppose.
Now, onto what my actual solution was. After finding that the plug prongs were 18ga, I went to my local hardware store and bought some 18/2 solid core wire. I bought 10ft, but you could get by with 6" honestly. It's cheap though, so nice to have around. I opened this up, and took the individually insulated wires out. Then I stripped about 1" worth, and soldered one wire to each leg of my 2.2Ω resistor. After this I put some heatshrink over the exposed bits, and then just stuffed it into the plug. There is no polarity to a resistor, so it really doesn't matter which way you throw it in. The wires should slide in with very slight resistance, and hold on even with some slight pulling. If it feels like it's binding or you're bending the wires trying to do this, stop. The loom from the car has very little to spare, so if you think you'll ever reinstall this you don't want to damage anything.
Here are some pics of what things looked like
After 20-30 miles I've had no CEL, no airbag lights, and I see no codes scanning OBD. Now that I know this is a viable solution, I plan on revisiting this to make it a bit more durable and hopefully put it away in some sort of 3d printed or aluminum enclosure. For the moment though, I have a viable prototype and can at least get it to my fabricator for its cage!
If anyone has any suggestions or is willing to share their solution, I'd love to hear it!
Old 03-24-2026, 01:32 PM   #3
Koba
Drives: 2020 BRZ
Good tip. Thanks!
I am kinda in a middle of the same thing.
Koba is offline   Reply With Quote
Old 03-27-2026, 09:54 PM   #4
smoltz
Drives: 01 911 Turbo, 03 G500
I know this likely won't be super helpful but.... you can pull all the airbags and the SRS module and suppress the light with some CANBUS commands to the dash. If you search older posts here you may find the info.
I would need to do a little research to tell you which ones.
In order to send those messages, you would need some device sitting on the CANBUS. Easiest way would be this box with some custom code which you would plug in to OBD2 port or CAN Options connector. This would be best option: https://mintonperformance.com/produc...4z2xH61X-E3rxA
If you are interested in doing this, let me know and I can try to whip up a program for that to address this.
smoltz is offline   Reply With Quote
Old 03-27-2026, 10:09 PM   #5
InstaGib
This is very useful, thank you so much for the suggestion.
I'm actually already planning on installing a module and switch panel to suppress the TPS light among some other track-friendly features using this canbus module here/
I'm not a stranger to programming, curious what you mean by whipping up a program? Is it reasonable to run all of this on a little Arduino or Raspberry Pi? I've considered something similar, but reliability is by far my #1 concern and I'm not sure if a hobbyist board like that is up to the task in a track car.
EDIT: Also to be clear, the lights aren't so much of a concern for me, the OBDII code is. If something suppresses the dash light but not the code from firing I'd still be interested in learning about it, but it limits the usefulness in my case
airbag delete, cage, srs
WTB Driver and Passanger Curtain airbag jprules Want-To-Buy Requests 1 10-24-2015 11:48 AM
WTB Passenger Curtain Airbag + Wheel Airbag markkisl Want-To-Buy Requests 4 08-26-2014 01:16 AM
FRS Stock Side curtain airbag for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 04-08-2014 10:32 AM
2013 SCION FRS Side Curtain Airbag sardox Want-To-Buy Requests 0 11-08-2013 12:53 AM
OEM Side Curtain Airbag Sehwan Kim Interior Parts (Incl. Lighting) 2 11-06-2013 09:12 PM
