Old 02-14-2026, 08:41 AM   #1
LS1M
Drives: 2015 BRZ
Built transmission?
Does anyone have experience with a built manual transmission? Something that can handle around 300 foot pounds of torque?
LS1M is offline   Reply With Quote
Old 02-14-2026, 08:43 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Stock will be fine. Don't dump the clutch or do any no lift-shifts. If it does take out a gear, spares are $300-500.
GEN2 trans fits in but hasn't been thoroughly battle tested
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 02-14-2026, 10:08 AM   #3
LS1M
Drives: 2015 BRZ
Maybe so, but that’s not the whole story. I have a Jackson racing supercharger already with the high boost pulley and the E85 conversion from Delicious Tuning. My supercharger died and I got a replacement and it doesn’t make as much power as the old supercharger did. I’m planning on upgrading to a.Sprintex 335 which makes a lot more torque, especially at lower RPMs. I recently upgraded to an Exedy stage one clutch and stupidly put Amsoil gear lube in the transmission. After driving it back-and-forth to work for a week, it now makes a horrible noise when decelerating in fourth and fifth gear. I changed it out to Motul Gear 300 but it still makes that noise. I’m worried that the stock transmission is toast now and I’m looking for alternatives. i’m considering getting a transmission from Jack’s so I don’t have to worry about it.
Old 02-14-2026, 03:17 PM   #4
DarkPira7e
DarkPira7e's Avatar
The critical flaw in the transmission is with the way the 4th gear syncro functions (not the syncro itself). Jack's can do all sorts of things but if they haven't addressed this, you'll have the same weakness.
I do agree that the Sprintex 335 makes dangerous torque because it's so high in low RPM.
Keep us apprised on how it works out!
Old 02-15-2026, 05:17 AM   #5
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
huh what is wrong with amsoil gear oil ?? I switched my gear 300 out for amsoil MTF since its a proper GL4 oil NOT a gl4/gl5 hybrid like gear 300 and its been great. Had it like this street/track for years now.
Did you use amsoil severe gear by mistake ? That is GL5 and not for our transmissions
autoracer86 is offline   Reply With Quote
Old 02-15-2026, 08:42 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Guys have broken the Jacks transmissions too. You really want bulletproof go CD009. Or just buy used stocks transmissions and keep a spare on hand.
Old 02-15-2026, 01:14 PM   #7
LS1M
Drives: 2015 BRZ
This is what I got
https://www.amsoil.com/p/amsoil-75w-...?code=MTGQT-EA
Old 02-15-2026, 05:44 PM   #8
autoracer86
Drives: Toyota GT86
Yup same stuff I been using. I just buy the bag version for easy fill
https://www.amsoil.com/p/amsoil-75w-...?code=MTGPK-EA
Sorry you had bad luck with it but that amsoil or the redline mt-90 is really good stuff for these transmissions. Do a search on here for gear300 and you will find people switching away from it.
Either way I am not sure the oil was the issue here anyway
Transmission lessons learned: (McLeod & FA24 transmission upgrade) GrandSport Tracking / Autocross / HPDE / Drifting 7 07-15-2023 11:09 PM
Help! Transmission mount to transmission bolt size Four_wheel_drifts Engine, Exhaust, Transmission 4 08-31-2020 02:55 PM
Built manual transmission or where to get sychros Rocket.BRZ Issues | Warranty | Recalls / TSB 50 08-01-2016 06:31 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
What was the coolest car built the year you were born? ichitaka05 Other Vehicles & General Automotive Discussions 80 09-04-2011 12:43 PM
