Drives: Scion FRS
Car Won't Start and Idk Why.
Hello!
So i have a 2015 FRS which has been sitting for a little while. i supercharged and now i am returning it back to normal. which first had an OFT stage 2 tune and then i Etuned with an ecu tec. as i removed the SC. i put the battery back(which was off for a period of time) my car wont start now. when i turn my key to accessories mode, no Light, just a few Clicking noises, but i have power to my headlights. battery is at 11.8v and my keyfob battery has been switched. I try to read it with my oft and ecu tec but no response. I haven't checked my ECU ground prongs and will at a better time. But i was hoping if i can get some help by picking the communities brains and hopefully be pointed towards the right direction. I would highly appreciate the feedback. |
Weight Weenie
Drives: 15 FR-S
Your battery sounds low. It should read 12.5-12.6
I would have the battery tested if you don't have the tools to do it yourself. |
Battery voltage only tells part of the story, you need to test for cold cranking amps.
Batteries most frequently die during 2 times of the year; when it gets hot and when it gets cold. Sound like you may have let it sit while it was getting colder out. |
Drives: Scion FRS
i think i found my issue, i replaced my battery. still no power to accesory mode nor will it crank, but i get power to my headlights. i started poking around with my multimeter and found one of the circuits is blown on the positive terminal. it'll go from 12v to .02 on the right side circuit. part comes in tomorrow and hopefully this is the answer. edit: for some reason the image wont load, but if imgur doesn't work later, i'll re upload |
Drives: Scion FRS
Drives: 2023 Toyota GR 86 Cup
That'll do it....
2023 GR Cup Car
Drives: Scion FRS
haha everything turns on but doesn't crank.
immobilizer blinks on accessory mode with key on. the starter doesn't have a lot of mileage, but i don't hear clicking. got a used one coming in and hopefully a swap works. i even got a new key fob and that didnt work(needed one anyways) also a Ignition starter coming in. haha im trying to narrow down on everything. |
Drives: 2013 frs red
Starter relay?
| Found Loose wire...?? IDK what it is | rikdrt1 | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 06-10-2020 12:42 PM |
| Car won't start. Limited with push to start. | uEih | Issues | Warranty | Recalls / TSB | 22 | 01-06-2017 11:54 AM |
| Car won't start, won't crank, no ecu communication | redlined600 | Issues | Warranty | Recalls / TSB | 10 | 07-09-2016 12:55 PM |
| Fitment Help! IDK crap about wheels. | K2R1D3R | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 03-25-2014 02:35 PM |
| idk how i feel about this. EBay fogs? thoughts | chriscross_tnt | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-30-2013 08:47 PM |
