Old 11-14-2025, 08:50 PM   #1
Eaton PSI
Drives: 2013 86
Anyone else having repeated throttle body failures?
I had a throttle body fail in january of this year. Yesterday the new one started to glitch just like the old one.
Erratic idle and cruise, and engine revs increasing to 2k-3k when pushing the clutch in with no input on throttle pedal. Cycling the throttle with the engine off, it sounds squeaky and unhappy.
The car has a harrop supercharger and the throttle body is rotated 90deg (black plastic cover faces upwards).
The last one behaved like this intermittently for a few weeks before I finally got stuck in limp mode.
Anyone else having throttle body issues?
2014 GT86, 2.2L big bore, harrop supercharged
Eaton PSI is offline   Reply With Quote
Old 11-14-2025, 11:01 PM   #2
ArCha
Drives: 2013 Subaru BRZ SWP
I've had similar, also on a Harrop. A few months ago I got stuck in limp mode as well, very annoying since there was no code until then. We noticed a voltage change when jiggling the jumper harness to the throttle but pulling the harness and doing a continuity check revealed no issues and we couldn't repeat the finding after we'd reassembled either. Tried cleaning the throttle body and MAF, no change.
We ended up swapping one of the relays and that seems to have resolved everything but I don't drive the car very often to be definitive. This was the same day as trying some of the other fixes. Just turned off the car, swapped a relay and when it turned back on the problem was gone.
ArCha is offline   Reply With Quote
Old 11-15-2025, 02:37 AM   #3
Eaton PSI
Drives: 2013 86
Yes, same here. No codes, just odd behaviour until it eventually goes into limp mode. Fortunately I keep an OBD dongle in the car so I was able to reset it and get home.
Some days it does it on the way home from work. It will start up fine in the morning and not glitch for another week.
I pulled an old throttle body apart and checked the motor on 12v. It sounds ok when horizontal but a bit odd in the vertical position. I wonder if the harrop throttle body relocation causes issues.
The gears were all completely dry, no trace of grease or anything. The shaft for the little idler gear actually had a tiny bit of rust on it.
Old 11-15-2025, 12:00 PM   #4
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Sounds like a Harrop problem.
I have had zero such issues running Edelbrock for several years now.
Perhaps Harrop have a solution???
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 11-15-2025, 06:39 PM   #5
Eaton PSI
Drives: 2013 86
Is the throttle body rotated on the edelbrock?
Old 11-16-2025, 10:57 AM   #6
Muskoka800
I’m thinking no but can confirm later today. The alternator was the only component I recall needing re-orientation during the kits install. The kit did include new, longer hoses for the TB coolant supply/return.
Old 11-17-2025, 07:13 AM   #7
Eaton PSI
Drives: 2013 86
I daily drive mine, around 35,000kms with the harrop on it.
Old 11-17-2025, 10:56 AM   #8
Muskoka800
Have you reviewed the posts in the Harrop owners forum under the Forced induction category?
There’s not much activity in these forums of late but likely some good historical info to be found there.
Good luck!
Old 11-18-2025, 02:07 PM   #9
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
The throttle body is rotated the same on the Edelbrock, 90 degrees CCW from the original position with the black plastic housing pointing upwards.
menikmati is offline   Reply With Quote
Old 11-19-2025, 07:22 AM   #10
Eaton PSI
Drives: 2013 86
When I get a chance I will open up the electric motor from my original bad throttle and see if there's anything interesting in there...
Old 11-22-2025, 11:42 AM   #11
Muskoka800
I stand corrected. That said, no TB issues here after years of enjoyment.
Old 11-30-2025, 05:44 AM   #12
Eaton PSI
Drives: 2013 86
So I opened up the electric motor from the throttle body that had a history of codes and limp mode. It all appears to be good. I'm pretty familiar with brushed motors as I am a lifetime RC nerd. Nothing wrong with this one. Weird. Maybe the sensor goes bad.
I had to destroy it to get it open so there's no fixing it even if there was something bad in there.
Old 12-02-2025, 06:17 PM   #13
Eaton PSI
Drives: 2013 86
upgrades!
It probably won't make any difference but it was easy to do...
Ball bearings fitted to the idler gear in the throttle body. This throttle was making a squeaking noise. When I opened it up there was no trace of any lubricant anywhere and the shaft for the idler was rusty.
Old 01-04-2026, 07:09 AM   #14
Eaton PSI
Drives: 2013 86
Today limp mode struck again! Throttle body #2 failed.
I had some spare time so I did some testing. I put my original bad throttle back on, still has same problem. I had already swapped the motor inside this throttle.
I removed the plastic cover plate from bad throttle #2 and fit that to bad throttle #1. Now throttle #1 has same issues as throttle #2.
Then I fit the plastic cover from another previously untested throttle (bought from water damaged car at wreckers) to throttle #1 and its all good!
It appears that the position sensor in the plastic cover is prone to failure. The throttles are made by nippon denso and I think variants of it are very common on many cars, subaru and others. I'm going to head back to the wreckers and get some more cover plates from similar throttles and see if I can fix my other bad one.
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 03:05 PM
Anyone having throttle issues? FRiSson Issues | Warranty | Recalls / TSB 13 09-25-2012 05:35 PM
Anyone else having bluetooth problems? Scooter Style Electronics | Audio | NAV | Infotainment 8 08-03-2012 06:38 PM
Anyone else having trouble finding an alignment place? track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-29-2012 11:26 PM
