Drives: 2013 FRS's (Hot Lava/GMetal Grey)
What Are You Using to Remove Old FIPG Material?
Just got into doing some engine repair (heads, timing cover, upper/lower oil pan), and I'm finding this Subaru FIPG material is a HUGE pain in the ass to clean/remove!
I've been doing automotive repair work for over 40 years and this stuff is the worst material I've ever had to deal with,.......PERIOD!! Instead of me getting into a rant, on the stupidity of using this stuff for just about every gasket surface in the engine, (instead of using rubber "O" ring, or traditional gasket material), how are you guys dealing with the removal/cleanup of the mating surfaces,.......and not marking up the surface in the process? I'd rather not get into using 3M "Roll-Loc" discs because the mar the surface, as well as fling FIPG debris everywhere. Is there a solvent that will disolve/clean cured FIPG? |
Wheels for Brains
I used this that I got from an aircraft technician friend, plus healthy elbow grease. I only did a small section, but maybe it could work for you
https://jusntyme.store/products/jnt411b60 |
Drives: 2016 Scion FRS Release Series 2#439
I bought a razor blade scrapper which nicely removed the thick, chuncky parts. Then used varsol to soften the remaining film which then scraped off cleanly. It is tedious work but cleaned up like new with time.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
Drives: Crapcan
Brass brush and brake clean always worked well for me. Let it soak a bit first.
| OFT - Using Old Versions | jsummers0123 | Software Tuning | 0 | 04-01-2019 04:18 PM |
| VIDEO GUIDE: NO Fuss Turn Key Digital Gauges using OBD-II and an old Smartphone | The Sentinel | Electronics | Audio | NAV | Infotainment | 0 | 01-28-2017 09:48 PM |
| Can Toyota's 103 FIPG silicone be used in timing chain cover? | Astroboy | Engine, Exhaust, Transmission | 16 | 08-24-2016 12:16 PM |
| Using higher quality brake fluid vs using cheap but changing more often | ayau | Tracking / Autocross / HPDE / Drifting | 41 | 06-14-2015 01:20 PM |
