Old 09-03-2025, 09:11 AM   #1
colHolm
Default User Title
colHolm's Avatar
WTB: Edelbrock TMAP wire harness (p/n 37-1570)
Hi - I'm looking for a replacement wire harness for the Edelbrock supercharger kit. It's the one that goes between the MAP and MAF on the factory harness, p/n 37-1570. I've reached out to Edelbrock but they don't currently have stock and weren't able to share when they would...
If you have an Edelbrock kit installed with the Delicious Tuning DBox, you should have this wire harness left over.
Probably a long shot, but figured I would ask.
colHolm is offline   Reply With Quote
Old 09-04-2025, 07:21 AM   #2
whataboutbob
AutoX-10/10ths every run
You might check with https://iwireusa.com/ to see if they can make you one if you need it ASAP.
Build thread:Here
Edelbrock SC TMAP harness Dann_86 Forced Induction 2 06-13-2023 01:55 PM
Wire Harness Burnt Wire SuperFR-S BRZ First-Gen (2012+) — General Topics 9 10-19-2022 10:44 PM
handbrake wire and reverse wire location Australia gt86 rsingh Electronics | Audio | NAV | Infotainment 0 01-16-2017 09:12 PM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
