Old 07-19-2025, 07:55 PM   #1
Yetti
Drives: FRS
Input requested from anyone running AP race brake kit with DS2500s
Recently bought a used AP Racing sprint brake kit for the front of my FRS when I got the kit I put in a new set of DS2500 brake pads. Now when I apply a certain amount of pedal pressure (not much probably like 15%) and are under a certain speed slowing down (like under 20 mph) it squeaks like crazy.
I don't get it I had the exact same pad compound (DS2500s) on my stock calipers and they didn't squeak at all. I was thinking of spraying down the rotors and pads as maybe the previous pads (hawk HPS) left some brake dust that is interacting with them? Also today at AutoX when driving at full attack they don't seem to squeak under the same conditions. I would like to blame it on the pads just squeaking when not up to temp although if that is the case then why were they so quite before in the stock calipers?
Anyone running AP Racing Spring brake kit on their car with DS2500s what is your experience?
Yetti is offline   Reply With Quote
Old 07-19-2025, 09:21 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
I've run them in the past. You would benefit from bedding them in.
Old 07-19-2025, 10:12 PM   #3
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
I have the Essex Sprint kit, I assume you have the same one. Mine squeak too, but I do have high temp pads that squeak on just about anything.
If it is an Essex kit, they do sell retaining springs that put pressure on the pads to reduce noise. They're quick to bolt on. But bedding them in is still definitely a good idea.
Walldodger is offline   Reply With Quote
Old 07-21-2025, 05:46 AM   #4
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I saw similar issues with my brand new brembo bbk and new pads. Took a fair amount of driving both normal and hard stops to finally get everything bedded in and working probably.
autoracer86 is offline   Reply With Quote
Old 07-21-2025, 04:19 PM   #5
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I had the EXACT same issue with the DS2500's and my Brembos. Here's a video:
The similarity here is the AP Racing kit and PP Brembos are fixed calipers. Fixed calipers inherently create more noise, then you toss in a bad that's more about performance and less about day to day driving. I even had some Girodisc backing plates and regular grease to help, but it was still that loud.
The solution is that red CRC brake disc quiet stuff. Either the spray or the "goop" liquid version. Many of my autocross buddies use the goop, I use the spray. I cake mine all up on the back in the spring and it usually lasts until the next spring (car is stored over winter). Car sees about 25 autox events and 4-5k street miles. If it's really cold, you might get a very very slight squeal at 2mph. It fully fixes the issue.
If you're tracking it a lot, you'd have to use this and see if it burns off quicker. You may need to reapply more if you're really cooking them on track. The CRC product dries up over time and with heat.
cmiovino is offline   Reply With Quote
Old 07-21-2025, 04:34 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
Funny video!
There's always the option of swapping out to a street pad.
Old 07-27-2025, 04:25 PM   #7
Yetti
Drives: FRS
Thanks for the feedback, glad this is more normal and not something wrong. As for the disc brake quite goop that can take track days?
Old 07-27-2025, 10:37 PM   #8
cmiovino
cmiovino's Avatar
I'd just try it and see what happens. At autocross, our brakes don't get much hotter than street driving. For me, it's the number of heat cycles that does it in over the year.
I could see one track day with high caliper temps doing it in. But who knows, maybe not.
Old 07-31-2025, 10:41 AM   #9
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
The key is to keep your discs bedded in properly. You need a pad transfer layer on the disc, and that should quiet them down dramatically. Please see these videos:
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 08-01-2025, 03:49 PM   #10
bhmax
Drives: 13 BRZ, 17 Focus RS
I had the same experience a few years ago running specific pads on both the stock brakes and the Sprint kit. Curious how much the new pad retention kit helps out as I’m looking for another brake kit.
bhmax is offline   Reply With Quote
Old 08-09-2025, 07:49 AM   #11
Yetti
Drives: FRS
On the topic of removing previous pad material would 4 big Autocross events be enough? I realize this kit in general is overkill for braking in a FRS. Anyone document a time frame they had to work through to get everything worked out?
Custom seat belt pads I requested now available shiumai Cosmetic Modification (Interior/Exterior/Lighting) 85 02-19-2016 04:45 AM
Feedback requested on TRD Brace Kit and TRD Strut Tower Bar donoman Scion FR-S / Toyota 86 GT86 General Forum 15 06-01-2015 03:59 AM
Advice Requested: Rebadged GT86 in the wrong location Veloist Cosmetic Modification (Interior/Exterior/Lighting) 39 07-19-2014 05:20 PM
Leg Motorsports Duck End Spoiler! Just as you requested. vividracing Exterior Parts - The Rest 2 12-09-2013 01:28 PM
Helping my dad decide on a new car. Thoughts from you smart people requested! D4ng3r Other Vehicles & General Automotive Discussions 19 12-13-2012 01:43 PM
