| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: 2025 Toyota GR86 Premium PP
Wondering if anybody is using the 1.24” long McGard spline drive lug nuts along with the extended Perrin studs.
https://mcgard.com/product/black-spl...allation-tool/ I’m wanting to use these with the oem wheels and Perrin studs when I’m not running a spacer. Do these fit the oem wheels properly and not bottom out on the longer stud? |
Drives: 24 GR Yaris, 23 GR86
Depends on studs lenght. Iirc for me McGard SW19 style lock worked on 10mm longer stud without a spacer but If i were you I'd just check the depth of lug nut with caliper.
Drives: '23 BRZ Limited
I'm about to jump into a meeting so I can't go check, do the stock wheels use "acorn style" lug nuts vs "conical seat" lug nuts like aftermarket wheels?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Well what’s odd is the stock wheels use the “non-bulge” conical seat, or at least that’s what they come with, yet the lug nut manufacturer websites say that the stock wheels should use the “bulge” style and aftermarket wheels should use the “non-bulge” conical seat… exactly the opposite of what I had. Car came with non-bulge and my new wheels from Tire Rack came with bulge style.
| McGard Spline Drive Locking Lug Nut Kit | iDriveProjects | Wheels and Tires | 0 | 05-29-2023 03:08 PM |
| Sheared lug studs are caused by bad studs or bad lug nuts? | daniloneil8 | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 09-10-2020 05:31 PM |
| CT/NY Black McGard spline drive lugs with locks New | Rob T | Wheels and Tires | 1 | 11-16-2019 10:43 PM |
| McGard Spline Drive Lug Nuts Set with tool, 12x1.25, Red Caps | Alan | Wheels and Tires | 4 | 05-19-2015 09:33 PM |
| SoCal 1 x rpf1 tony Angelo , gold mcgard lugs spline drive with keys | SliverBrz | Wheels and Tires | 8 | 07-10-2014 04:57 AM |
