Old 05-16-2025, 03:39 AM   #1
Mont-E
Drives: Scion FR-S
Headlight bulb question
I have to replace the headlight bulb for the low beam and after searching here, it's suggested that the HIDs are better for the projector.
Searching for the HIDs, I am seeing things like a ballast kit. Do I need that? Currently I have LED bulb installed with a small block (relay?).
I searched for H11 HID bulb, didn't get any decent results. Is this the correct term that I should be searching for?
2015 Scion FRS
Thank you
Mont-E is offline   Reply With Quote
Old 05-16-2025, 02:40 PM   #2
slim blanco
slim blanco's Avatar
Drives: 2017 86
yes, the low beam is an H11 bulb type, so you would need an H11 compatible HID kit. the kit will come with the ballasts and everything you need to plug and play. you plug the bulb into the ignitor, ignitor into the ballast if it's not already attached, and the ballast into the car's bulb socket. i always recommend getting a 35watt kit over the 55watt, 55 is usually overkill in terms of brightness. color temp is really a personal choice. i like 6000k myself, but people usually go with a temp between 4000-5000k for a pure white looking light output.
for searches, you'll want to search for 'h11 hid kit', not just bulb.
slim blanco is offline   Reply With Quote
The Following User Says Thank You to slim blanco For This Useful Post:
Mont-E (05-24-2025)
Vland Headlight HID Bulb question (Need HELP) TMXSTAR Cosmetic Modification (Interior/Exterior/Lighting) 2 03-07-2020 08:15 AM
BRZ and FR-S HID Headlight Bulb Upgrade | BRZ FR-S Video JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 9 02-08-2014 01:34 AM
Headlight bulb housing SavingManuals Issues | Warranty | Recalls / TSB 2 11-29-2013 12:00 AM
FR-S Headlight Bulb Swap tennisfreak Cosmetic Modification (Interior/Exterior/Lighting) 9 08-29-2013 03:48 PM
22w LED H11 Headlight Bulb (from AutomationLED) Review Chewie4299 Cosmetic Modification (Interior/Exterior/Lighting) 10 04-02-2013 07:02 AM
