Old 03-26-2025, 07:59 PM   #1
alfakarl
Drives: 2013 Scion FR-S & Subaru BRZ
2015 FA20 into 2013 BRZ Swap Quations
I'm installing a 2015 manual FA20 in a 2013 manual car. I've seen conflicting information on if it's plug and play or not and need some definitive answers.
1. Can I simply drop in the 2015 engine and use my original ECU?
2. Do I have to use my original 2013 wiring harness, coils and ECU?
3. What sensors would I need to change out if I use my 2013 harness?
4. Can I use the 2015 wiring harness and my ECU?
5. Can I use the 2015 ECU without programming?
6. Do I need to swap injectors if I use the 2013 wiring harness?
7. Do I need to swap injectors if I use the 2015 wiring harness?
Thanks!
alfakarl is offline   Reply With Quote
Old 03-26-2025, 10:20 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Everything is plug and play, as long as the engine harness is still attached to the 2015 engine.
EndlessAzure is offline   Reply With Quote
Old 03-27-2025, 01:35 PM   #3
alfakarl
Can I use the original ECU from the 13?
Old 03-28-2025, 12:26 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes.
The only difference is if you use the 15’ engine harness and coil packs, you have upgraded coil packs.
harness, swap
2017 MT FA20 engine swap into 13 BRZ noautobrz BRZ First-Gen (2012+) — General Topics 18 01-31-2023 01:40 PM
2017 fa20 engine into 2013 car? ROADRACER Engine, Exhaust, Transmission 91 12-28-2021 11:52 PM
Performing FA20 swap with new FA20 Ctoner2653 Engine Swaps 8 09-24-2021 08:40 AM
Blown 2016 FA20 swap 2017 FA20 HRLQN Engine Swaps 11 10-15-2019 07:17 AM
Question on a WRX FA20 swap into a FRS Stoll_It317 Engine Swaps 6 07-27-2017 05:33 PM
