Drives: 2017 Toyota 86
VSC and ABS lights turn when Headlights Switch On
My VSC and ABS lights turn on when my headlights switch on. They will stay on until I restart my engine.
I'm not sure exactly when this issue started as it only happened very rarely and I originally assumed it was a wheel speed sensor. One of the first mods I did to my car was aftermarket headlights and taillights, and I've read around that sometimes those changes can cause this to happen. However, as time has gone on it has become more common and now after I replaced the LEDs in the gauge cluster the warning lights almost always turn on whenever the headlights or marker lights are switched on. If anyone has any ideas of what might cause or where to start to diagnose this, it would be appreciated. Edit: After replacing the aftermarket 4th taillight the previous owner installed, the problem has gone away entirely. Last edited by Hazel; 03-08-2025 at 12:26 PM. |
not playing cards
Reinstall your stock lights first.
#4 | |
not playing cards
Disconnect one bulb and test drive until the MIL is thrown. Leaving it disconnected, disconnect another and repeat testing until the MIL is no longer thrown. Then, leaving that last bulb disconnected, reconnect all the others. Does the MIL get thrown again, or did you find the bad/noisy unit? edit: Okay,,, not MIL, bur rather that odd combination of lights. Is that limp mode?
#5 | |
However, after a series of pulling fuses and disconnecting things, I have narrowed it down to the 4th brake light being the issue. The previous owner of my car installed an aftermarket one and completely disconnecting it seems to solve the problem. Might be something related to the fact that the wiring for it is tapped into the taillight and wires to provide taillight functionality, unlike the stock one. I ordered a different one and I will see if I have any luck with that one. |
#6 | |
Drives: frs
| Scion frs headlights side marker lights doesn’t turn on please help! | Jayy32 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-26-2021 01:30 AM |
| 2015 OEM Headlights, turn signals, side markers, reverse light, & Valenti tail lights | Vinsanity091 | Exterior Parts (Aero, Lighting, Etc.) | 4 | 06-11-2017 05:56 PM |
| Winjet headlights cause the LED fog lights to turn off | Paul_541 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-21-2017 12:34 AM |
| FR-S/BRZ Turn Stalk w/fog light switch | Trojan_SC | Audio/Visual, Electronics, Infotainment, NAV | 8 | 11-09-2015 01:41 AM |
| How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-30-2013 11:42 PM |
