Old 01-03-2025, 10:12 AM   #1
gpvecchi
gpvecchi's Avatar
Rear roll center correction
I fit a front roll center correction (lowered 30 mm), I can feel the benefits.
But now, what about the rear?
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
Trap63 (03-29-2026)
Old 01-03-2025, 11:07 AM   #2
Racecomp Engineering
I don't know of anything that you can bolt on easily.
I've been tempted to drill a hole upwards for the inner mounting point of the rear lower control arm but it's not exactly easy. Something like this:
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
gpvecchi (03-30-2026)
Old 01-03-2025, 01:37 PM   #3
gpvecchi
gpvecchi's Avatar
There are some japanese brands that have arms for that, but they clam that the ride height will change a lot, like 2 cm.
Old 01-03-2025, 03:04 PM   #4
marco_mc22
Drives: Toyota 86
I think the cheapest mod would be fitting adjustable upper arm bushings, moving the arm in a slightly better position. Ideally you have to raise the inner part (subframe side).
Anyway...considering how the rear end of this car behaves, I wouldn't worry much about the rear RC, especially within 25mm of lowering.
SPL if I'm not wrong makes adjustable shims and bushings for the entire subframe, but raising RC would increase Anti-squat, so you might need a traction mod as well...
marco_mc22 is offline   Reply With Quote
The Following 3 Users Say Thank You to marco_mc22 For This Useful Post:
gpvecchi (01-04-2025), NoHaveMSG (01-07-2025), Racecomp Engineering (01-03-2025)
FS: Whiteline Roll Center/Bump Steer Correction Kit smg1138 Brakes, Suspension, Chassis 1 11-13-2019 10:38 AM
Whiteline Extended Ball Joints (Roll center correction) thunderlights Canada Classifieds 1 07-07-2019 12:56 AM
Roll Center correction Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-14-2016 03:22 PM
For Sale: Whiteline roll center correction kit BNIB xDanger_208x Brakes, Suspension, Chassis 3 06-23-2014 09:56 AM
Whiteline Roll Center/Bump Steer Correction Kit! MAPerformance Brakes, Suspension, Chassis 3 10-23-2013 10:24 AM
