Old 12-08-2024, 03:40 AM   #1
DatBrzQ60
Drives: BRZ Ts
Start up Blinking engine light
Hey wondering if any1 can shed some information if this is normal behaviour or not . On start up car engine light blinks once and remains off I don’t recall it ever doing this, the blink part . Car is tuned via ecutek and no codes are present . Why would it be doing this . Video link attached any help would be appreciated 2020 brz ts turbo ECUtek tuned . Pre sure on other start up vids it doesn’t blink once. Is this an ecutek thing TIA
DatBrzQ60 is offline   Reply With Quote
Old 12-09-2024, 11:49 AM   #2
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Completely normal. If you feel unsettled about that, just run the EcuTek and clear the DTC codes
ZC6_STi is offline   Reply With Quote
Old 12-09-2024, 03:01 PM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
It doesn't blink in that video. @DatBrzQ60 did someone reprogram your gauge cluster? I see you're in Australia and I'm not sure if the programming is different over there or not.
I would hook up a code reader and see if it pulls any codes, if not, I'd just move on.
Joon525 is online now   Reply With Quote
Old 12-09-2024, 05:43 PM   #4
DatBrzQ60
Drives: BRZ Ts
No codes present on the ecutek code reader .
Old 12-09-2024, 05:45 PM   #5
DatBrzQ60
Drives: BRZ Ts
Just tuned with ecutek , yeah prob moving on car doesn’t present any codes and data logs look alright . Just thought something might’ve caused it as I’ve never seen it blink usually just starts up like in the vid you posted with no blinking .
Old 12-09-2024, 05:57 PM   #6
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
I run ECUTek. I was tuned by Delicious Tuning and my engine light will do a couple flashes about every 30 seconds until the car is warmed up. The info from ECUTek says that this is the notice that VVTi is not ready until warmup. (If I recall correctly)
RongTurnRacing is offline   Reply With Quote
Old 12-10-2024, 01:42 AM   #7
DatBrzQ60
Drives: BRZ Ts
Is yours similar to mine where it blinks and then turns off on start up? Mine just does it when starting the car otherwise during driving operations it never comes on .
Old 12-10-2024, 06:09 AM   #8
RongTurnRacing
No, not exactly. Mine does it when it first starts but also does it for a few minutes until the car is completely warmed up.
No start No crank Anti-theft blinking 02maher Issues | Warranty | Recalls / TSB 37 05-18-2020 09:00 AM
Engine Immobilizer Light Blinking with Power Off yackery Issues | Warranty | Recalls / TSB 4 01-01-2018 03:50 PM
Popping noise from engine bay during start up, free rev, light roll on throttle heeltoe86 Tracking / Autocross / HPDE / Drifting 44 12-01-2014 09:28 PM
Engine oil light briefly flashes after start up shu5892001 Issues | Warranty | Recalls / TSB 6 09-24-2014 12:52 PM
What is that blinking dash light when the car is off? JayNutter Scion FR-S / Toyota 86 GT86 General Forum 7 02-03-2014 10:59 AM
