Old 10-24-2024, 03:30 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Shark-fin antenna question
I stupidly hit my garage door with my antenna and broke it loose. There is some confusion about that entire assembly. The Toyota part number is SU003–05516 but I don't think that's what I need. The fin housing has a wire that attaches to a circuit board bolted to the roof from underneath and I think the circuit board is what I need. I can't find any blowups anywhere that show it, and my local Toyota dealer says none of those part numbers are available in the country. The antenna housing I have is still usable but has torn loose from the circuit board, and that's what I think I need. I can't find a part number or blowup anywhere for that board. Is anyone familiar with these?
Qwimby1 is offline   Reply With Quote
Old 10-24-2024, 05:27 PM   #2
rande
rande's Avatar
Drives: Spyder, MR2, FRS, Tundra
Try a Pick-N-Pull.
rande is offline   Reply With Quote
Old 10-24-2024, 08:37 PM   #3
Qwimby1
Originally Posted by rande View Post
Try a Pick-N-Pull.
There's no logical way to do that. The fin housing has a wire that attaches to a little plastic cap that covers the circuit board. The wire continues through the cap and must have been attached to the board but I can find no obvious point of connection. My only hope may be to find a fully-connected assembly on the used market.
Old 10-24-2024, 08:52 PM   #4
rande
rande's Avatar
No logical way??
Find a wrecked FRS/BRZ at a Pick-N-Pull (salvage yard, car-part.com, etc.). Remove the entire assembly and any other parts you think you might need/want. Swap the parts onto your car. Should be cheap.
Even cheaper. Find a FRS/BRZ and take apart their antenna to see where the wire is attached. If your board is still good the wire may be able to be reattached.
Old 10-25-2024, 07:43 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Source of confusion emboldened for emphasis.
Old 10-26-2024, 02:54 PM   #6
Qwimby1
The second Toyota dealer I talked to found the part I'm looking for in a local warehouse and I should have it in a day. I still don't know the part number. it's not in the blowup on the Toyota website.
Old 10-26-2024, 03:42 PM   #7
Qwimby1
Part # is SU003-02655
Old 10-26-2024, 07:20 PM   #8
Ultramaroon
not playing cards
That's the amp for the original rubber ducky antenna.
Shark Fin Antenna?! JesseTheFlash Cosmetic Modification (Interior/Exterior/Lighting) 4 12-23-2014 05:13 AM
FS: SWP VG Shark Fin antenna Khazzy Exterior Parts (Aero, Lighting, Etc.) 2 07-03-2014 09:00 PM
Shark fin antenna-fr-s Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 39 03-11-2014 03:14 AM
Shark Fin Antenna Sparda29 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-20-2013 10:49 PM
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 12:44 PM
