Old 09-19-2024, 11:10 AM   #1
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
Part number for 2015+ Oil Temp Sensor
I have a 2013 FRS and am working on updating the coils/wiring harness to the 2015+ harness (seems some 2014's got an incremental update as per the TSB, but with dfferent part numbers).
2015 engine wiring harness part number: 24020AG080
2015 ignition coil part number: 22433AA730
So far I have obtained the 2015 harness/coils based upon the part numbers above, but in addition to the changes to the coil and its connection, the oil temp and coolant temp sensors were updated with a new connector. Even though the new harness can be repinned to use the old connector, I prefer to install new sensors. To that end, I cannot find a part number for the oil temp sensor. The new coolant temp sensor Toyota part number is SU003-04714.
Based on my perusal of the factory service manual, the connectors are the same between coolant/oil temp sensors, and also the physical appearance is the same. Further, the temperatures of the two sensor are not dissimilar which leads me to think that it is possible/likely that they are the same part.
Can anyone shed some light on this? A confirmed correct part number for the 2015-2016 oil temp sensor would help.
See below for the 2013-2014 temp sensor connector (C21 is oil temp & C35 is coolant temp). The other image is of a male end of a 2015 coolant temp sensor.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car)
2003 Nissan Pathfinder (R50) (current car)
2018 Lexus GX460 (current car)
2023 GR86 Neptune M6 Premium (Leased)
Prodigalson is offline   Reply With Quote
Old 09-19-2024, 03:18 PM   #2
Prodigalson
ThisGuyLoves86's
Though by no means a definitive answer, this does seem to support my theory that the oil & coolant temp sensors are the same part
O2 Sensor Clips Part Number lc300 Engine, Exhaust, Transmission 0 09-12-2019 12:52 PM
Part number for 2015 OEM Sharkfin, kneepads, etc? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 12 08-30-2014 02:33 PM
OEM 2015 WRX/STI Sharkfin Part Number illmatic Cosmetic Modification (Interior/Exterior/Lighting) 3 03-29-2014 06:01 PM
part number for map sensor (vortech kit) cjsporl1996 Forced Induction 0 03-16-2014 11:05 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
