Drives:
2nd Gen GR86 / BRZ - STR Thread
Figured I’d start a thread here too for people to post.
I’m in a 23 GR86 Premium with the following mods: RCE T2 7/9k 22MM FSB Perrin on soft Stock rear bar (15mm) 17x9 RPF1 245/40/17 A052 Vorshlag high caster camber plates SPL End Links front and rear (short ones for the front) Alignment is: Front -4.5 Camber 0 toe 7 caster Rear -1.1 camber 0.40 toe in total Height: LF - 141mm LR - 146mm RF - 144mm RR - 149mm Rake - 5mm Total Weight w Driver (7 gallons) - 3,014 Sent from my iPhone using Tapatalk |
Drives: 2023 GR86 - Track BRed Premium 6M
- Shaftworks single adjustables 6k/9k
- Karcepts front bar with larger center section and SPL endlinks - SPC Front camber bolts - RacerX rear upper arms - Perrin 16mm rear bar with SPL endlinks - Whiteline rear subframe bushings - Shaftworks-tuned OS Giken LSD - 17x9 +45 TWS T66-F with a 10mm spacer in front - 245/40/17 Yokohama A052s - ARP extended studs with CSG lugnuts - JDL UEL catted header - JDL dual-resonated front pipe - Borla S-Type catback exhaust - 93 octane tune by Zach at Counter Space Garage (7800rpm redline) - Stock brakes Alignment: -4.5 front camber 0” total front toe -2.5 rear camber 2/16” total rear toe For 2025, I am planning to bump up the front camber to -5.0 and see how that feels.
STR also-ran
| Trueno Blue GR86 Thread | VoltsFRS2013 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 63 | 07-12-2023 01:56 AM |
| Northern VA - GR86 Partout Thread | VoltsFRS2013 | Mid-Atlantic | 0 | 05-12-2023 12:26 PM |
| Neptune Blue GR86 Thread | PrayForRain | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 164 | 12-03-2022 05:52 PM |
| LED Taillight Compilation Thread for GR86 | pansontw | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-24-2022 03:11 AM |
| Halo White GR86 Thread | halogr86 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 43 | 06-05-2022 03:55 PM |
