| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: BRZ 2013
Anyone see this DTC combination before?
Hey all,
Last night I got the traction control + check engine lights come on. I parked at home, turned off the car and tried to turn it on to see what would happen. The engine wouldn't turn. Plugged in Ecutek and saw P0171 (system too lean bank 1), P117b (DI fuel performance Does not come on DTC), and C1201 (an ABS code with no description). I've been running ACE 350 + Flex Fuel (Delicious Tuning) + DT E85 tune for about 5 months. Recently been using E85 primarily for past 4 tanks, switched back to premium, then got another E85 tank. The station is a few blocks away and no one ever uses it, so it's convenient. I noticed my air intake housing was loose so I'm going to try MAF cleaner. Also, heard a noise from the header area some time ago so going to ask the shop to check for a leak. My research isn't pulling up a good solution other than to try those two things, so if I find out what it is I'll post it here. If you have seen this can you let me know the potential issue? Thanks |
Drives: Subaru BRZ 2017
are you running catless header?
Drives: 2013 frs base
You indicated the engine won't turn. Is you battery drained? I've read where a failing battery will give weird symptoms.
The Dictater
Drives: '13 Red Scion FRS
If it's not turning over at all, you probably have an electrical problem, likely the battery or some connection to the battery. Aftermarket headers increase engine bay heat (those factory heat shields are pretty good at insulation) which can contribute to battery issues.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
| rocket bunny V1/V3 combination | RIĐO | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-31-2018 03:41 PM |
| Best combination of headers and cat back’s | sbmantas | Engine, Exhaust, Transmission | 44 | 04-20-2018 09:27 PM |
| Exhaust combination | Karl07 | Engine, Exhaust, Transmission | 5 | 11-04-2016 02:05 AM |
| Combination Oil Cooler | Spartarus | Engine, Exhaust, Transmission | 6 | 05-23-2015 08:45 PM |
| Opinons on this combination | cjcoupe | Engine, Exhaust, Transmission | 6 | 02-04-2014 12:45 AM |
