Old 08-19-2024, 02:22 PM   #1
RaidenRacingCo
RaidenRacingCo's Avatar
Drives:
Cartek ISO for BRZ Question
I’m currently in the process of building my car into a GLTC race car. I’m looking to install a battery kill switch, specially the Cartek GT battery iso kit. I was wondering, since my harness is still stock with my FA20, if I repurpose my current negative tie that connects to the negative terminal, will I be tag that into a clean chassis ground? Or will I run into issues? Since the Cartek requires everything to be ran into a chassis ground, then a direct line from the negative terminal to Cartek, figured if I lop off the current terminal, and replace it with a proper fitting for a bolt, it should in theory work right?
RaidenRacingCo is offline   Reply With Quote
Alignment Shop in SD and quick question question JohnTran619 Southern California 5 11-21-2018 01:40 PM
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Has anyone fitted CARTEK shift lights ?? 000 Racing AUSTRALIA 5 06-12-2013 06:26 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
