Old 08-10-2024, 05:15 PM   #1
deadr0ze
Drives: 2013 Rocket Bunny FRS
FRS Understeer Issues - Rear Drop Knuckles
[U]Hello everyone!
Looking to see if anyone can provide some input on some interesting steering issues I am having that I have never had before;
- upon turn in the traction control absolutely loses its mind and activates about 6 times before finally being stable again. This is on 90% of turns around 50-65 MPH, these are the same turns Ive taken before at upwards of 70 MPH
- with traction control off, the car has grip and only has mild stuttering around the same speeds and steering angle
I did a few suspension mods all together but mainly it was spherical bushing arms rather than poly, the most impactful mod that was done was the GKTech Rear Drop Knuckle/RUCA combo. Really at a loss as to how to remedy this current so looking forward to any and all input. Below are suspension mods/specs and a photo of the car for more info. Thanks in advance!!
Suspension:
Annex Club Spec Pro (7k F, 8k R)
GKTech Tie rod end (15mm RCC)
RacerX FLCA
RacerX Endlinks
Hotchkiss Front Sway (tested both settings with minimal difference)
PBM Diff Riser Bushings
VooDoo13 Subframe Bushings
GKTech RUCA
Stance 60mm Drop LCA
VooDoo13 Toe Arm
VooDoo13 Trailing Arm
MCA Traction Mod
Stock Rear Sway
Spherical Endlinks
18x11, 295/35 Michelin PS4S Squared
Front:
2.5 Deg Camber
0 Toe
6 Deg Caster
Rear:
1 Deg Camber
1/16 Toe (1/32 per side)
Aero:
75” Wide Front Splitter
Professional Awesome Large Diffusers
Voltex 1800mm
deadr0ze is offline   Reply With Quote
Old 08-10-2024, 08:46 PM   #2
whataboutbob
AutoX-10/10ths every run
1) Is the rear toe value toe-in, or toe-out?
2) You might check your rear wheel speed sensors to make sure they aren't damaged. I have damaged mine in the past when swapping rear axles when I forgot to remove them from the rear knuckle. There's not a ton of clearance between them and the axle, and the tips can get damaged easily.
Build thread:Here
Old 08-11-2024, 04:05 PM   #3
deadr0ze
Toe value is toe-in, and I would like to say that they are in good condition, done axles a few times and never forgotten to remove them but there is definitely always a chance so Ill check those asap
Old 08-11-2024, 07:49 PM   #4
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Did you recalibrate the steering angle sensor after the mods....if not. start there.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 08-11-2024, 09:00 PM   #5
deadr0ze
I never would have thought of that!! SAS have never been recalibrated to my knowledge. I will do so tomorrow and report back
Old 08-14-2024, 06:40 AM   #6
marco_mc22
Drives: Toyota 86
Had a similar problem once and it was a lack of rear droop travel, due to lowering LCA's design. Changed the arms with standard ones first and then with pillow ball hard race model and the problem was solved.
marco_mc22 is offline   Reply With Quote
anyone running aftermarket rear knuckles? 85258 Tracking / Autocross / HPDE / Drifting 1 06-10-2024 12:03 AM
FS (NY) Rear knuckles with cusco sphericals AxisPower Brakes, Suspension, Chassis 1 03-14-2024 09:37 PM
WTB Front Rear Knuckles pope Want-To-Buy Requests 3 10-23-2023 01:05 AM
Understeer Issues - Toe Alignment Issues? NutGud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-29-2021 08:45 PM
Drop Knuckles instead of lowering Springs or Coilovers FRSPacNW DIY (Do-It-Yourself) Guides 19 10-09-2017 12:42 AM
