Old 08-09-2024, 05:21 AM   #1
HSC
Drives: Whiteout FR-S
FRS - front, passenger side, parking light problem
Noticed my front passenger side parking light stopped working (light below headlamp this is also turn signal). My side marker on the passenger side works as well as turn signal indicator. Replaced bulb and still have same problem. Driver side functions correctly. Before I get a multimeter to troubleshoot, any suggestions on potential fixes? Note: I recently installed monogram headlamps on my 2013 FRS (following instructions found here) and they’re working fine and I didn’t touch the wiring to that parking light/signal. I did, however, tap into the DRL resistor which is in the vicinity of that parking light but do not believe there should be any impact. Any help would be greatly appreciated.
HSC is offline   Reply With Quote
Old 08-12-2024, 06:07 PM   #2
HSC
Nvm. Found out I had multiple bad bulbs.
Parking brake light probelm and check engine problem CSkap21 Issues | Warranty | Recalls / TSB 12 03-09-2018 07:19 PM
Front turn signal/Parking Light and Side marker not working s14sleepyeyez Issues | Warranty | Recalls / TSB 1 10-19-2014 11:43 PM
FRS Passenger side tail light (OEM) (WTB) supadre123456 Exterior Parts (Aero, Lighting, Etc.) 9 05-21-2014 04:42 PM
WTB: Raven front bumper plus front underpanel and passenger side front fender liner THEmailman Want-To-Buy Requests 1 04-20-2014 01:05 AM
WTB: Passenger-side tail light retrosmiths Want-To-Buy Requests 9 10-05-2013 12:41 AM
