Old 07-18-2024, 09:10 PM   #1
bryansuriel3
bryansuriel3's Avatar
Drives: Red Brz
Help Brz electrical issue
I have a 2013 Subaru brz limited it's been sitting for 3 years due to a blown motor I purchased a used motor from Jdm motors and swapped everything to that new motor and installed it into the car I attached every connector swapped most of the fuses that show the amps I haven't checked the relays the car cranks but does not start.
The obd2 port doesn't work and the windows wont go down also the car doesn't lock/unlock itself seems as if the door isn't powered. The ac display doesn't work the seat warmer button, mirror adjuster and the wipers
Things that do work is the dash , the dome light, doors floor lights, high beam too Ive swapped fuses in the engine bay and the interior
Update:
the electrical issue was the battery terminal fuse I swapped it I'm able to use my obd now and windows work everything else works
still wont start it cranks but it sounds like a weak crank with flickering going on
I scanned the car 4 permanent codes came up
P0011
p2109
p0345
p0335
i already replaced the crankshaft sensor
and cleared the the codes and its still there
there's a hose on this new engine on top of the cam plate there wasn't one on my original engine i guess what ill do is unbolt it and put a plug unless you guys have any suggestions
as for the crankshaft position sensor plate i completely forgot to install it on to the new engine thanks opie
I'm going to drop the Transmisson instead of pulling the engine again smh
ill keep you guys updated
bryansuriel3 is offline   Reply With Quote
Old 07-19-2024, 11:44 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'm assuming that you got an engine for a 2013 to 2016 and not a 2017 to 2020.
And, you've triple checked all electrical connections.
Old 07-20-2024, 09:21 AM   #3
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Did you install the correct crankshaft position sensor plate? It's the round plate that gets bolted between the block and the flywheel, see pic. If you use one off the wrong engine combo, the ECM won't see the correct crankshaft signal, this results in a crank no start.
Like blsfrs said, what engine did you install? Did it come from a 2013 -216 model, or something newer?
Are you sure everything is connected? Your other electrical issues sound like something has been missed...
Is the starter ground attached? It bolts to one of the two starter mounting bolts, come from the negative battery terminal.
The two engine grounds? Bottom of the head to frame rail on both sides?
All 3 connectors from the body to the engine harness?
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 07-20-2024, 11:01 AM   #4
whataboutbob
AutoX-10/10ths every run
Don't forget all 3 bolts for the DI ECU too. That'll cause issues.
Build thread:Here
Old 07-20-2024, 08:04 PM   #5
bryansuriel3
Drives: Red Brz
posted an update
Old 07-21-2024, 12:27 AM   #6
whataboutbob
"there's a hose on this new engine on top of the cam plate there wasn't one on my original engine i guess what ill do is unbolt it and put a plug unless you guys have any suggestions"
...sounds like you have an auto motor...
Build thread:Here
Old 08-29-2024, 07:32 PM   #7
bryansuriel3
Drives: Red Brz
Update:
i put the crankshaft sensor plate on and tried to start it
it cranks but it won't start
as it was cranking i heard the exhaust for a split second checked the exhaust light smoke came out but not too much it disappeared
i tried cranking again the same thing happened so i decided to get starting fluid and then this happened
scan shows permanent codes
p0335 crankshaft position sensor a
p0011 intake camshaft position timing over advanced bank 1
p2109 throttle pedal position sensor a minimum stop performance
p0345 camshaft position sensor a circuit bank 2
i tried to clear the codes but they won't go away
any thoughts?
the crankshaft sensor is brand new i just bought it
Old 08-29-2024, 08:55 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
That sounds bad in a non-electrical way.
Old 08-31-2024, 12:19 PM   #9
blsfrs
blsfrs's Avatar
When you put the plate on, did you line up the dowel?
Electrical Issue Fa20Toybaru Issues | Warranty | Recalls / TSB 13 09-20-2022 09:01 PM
Strange electrical issue Sniepster Issues | Warranty | Recalls / TSB 14 11-20-2020 09:54 AM
Complex BRZ Electrical/ECU Issue -- Need help! mackemode Issues | Warranty | Recalls / TSB 14 07-09-2020 11:45 AM
Electrical Issue TeamJacobs111711 Issues | Warranty | Recalls / TSB 15 08-06-2018 01:41 PM
Weird Electrical Issue Relogical Issues | Warranty | Recalls / TSB 0 04-19-2018 02:09 PM
