Old 07-13-2024, 09:28 PM   #1
Kizer00X
Kizer00X's Avatar
Drives: Subaru BRZ pearl White
Act pressure plate wear (hard/hot spots
I'm currently doing some clutch work due to deciding to swap out a act light weight flywheel. Unfortunately I found these hot spots on the pressure plate and was concerned. The clutch pressure and friction plate is only about 3 months old. The pressure plate is smooth, so I was thinking it is fine, but I'm seeing and herd hotspots like this has ruined the clutch. What do you guys think?
Kizer00X is offline   Reply With Quote
Old 07-14-2024, 06:19 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What kind of disc are you running and what does the flywheel look like? Looks like a lot of heat. Was it slipping?
FS - Stock Clutch Flywheel/Friction Plate/Pressure Plate and Clutch Release Arm jnorloff21 Transmission and Driveline 0 04-28-2022 10:43 PM
Taillights​ with hard water spots inside Jajanken86 Cosmetic Modification (Interior/Exterior/Lighting) 9 03-31-2017 01:35 AM
how to remove hard water spots DarkestBuddha Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 08-10-2014 06:53 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Hard water spots Double4Free Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-01-2012 10:14 AM
