Old 07-12-2024, 01:39 PM   #1
dmorgan38
Drives: 2013 fr-s
Changing springs front and rear.
I have lowering springs on my 2013 FRS. I will be removing the Whiteline springs and replacing with Eibach. If I remove only the top mounting bolts leaving everything attatched at the bottom will the suspension sag enough to change the springs?
dmorgan38 is offline   Reply With Quote
Old 07-12-2024, 02:12 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You need to remove the struts to change springs. They're not under much tension and can be done by hand.
Stock Springs from 2017 BRZ PP (Front & Rear) RWDWeekend Brakes, Suspension, Chassis 0 10-19-2020 10:02 PM
CA: Swift 5k springs front and rear Clutch Dog Brakes, Suspension, Chassis 13 03-12-2020 02:36 PM
FS: BRZ OEM Front & Rear Springs Lebby83 Brakes, Suspension, Chassis 2 06-14-2016 11:05 AM
SoCal - F/S/T - OEM Front/Rear Struts, Springs and Top Hats Captain Curt Brakes, Suspension, Chassis 0 04-21-2016 06:39 PM
OEM FRS front & rear springs, and front endlinks VacantSky Brakes, Suspension, Chassis 3 09-26-2014 05:14 AM
