Old 05-03-2024, 03:56 PM   #1
H_K
Drives: '13 Scion fr-s
Can I put a 2018 BRZ exhaust on my 2013 FR-S?
I have an aftermarket header (JDL UEL), so everything from the header back I am interested in swapping out. My FR-S has quite a rusty exhaust from regular winter driving and have some small exhaust leaks all along the way.
I was looking for another healthier OEM exhaust to replace it with.
Someone near me is selling a 2018 BRZ exhaust with low kms, and I'm wondering if I would have any issues bolting it to my FR-S.
H_K is offline   Reply With Quote
Old 05-03-2024, 04:10 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Yes. The difference between the years is the axle-back portion (with some aftermarket exhausts supporting both pre- and post-facelift). Since you are replacing everything to the header you should be good.
Ohio Enthusiast is offline   Reply With Quote
Old 05-03-2024, 05:18 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I did this with a 2017 cat back, works perfectly. I cleaned it and coated it to help stop corrosion
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 05-03-2024, 05:54 PM   #4
2.2Lude
2.2Lude's Avatar
No issues. I put a 2017 exhaust on my 2014. If you're replacing gaskets(which you should be) the front donut gasket is the same across all years, 1st gen at least IIRC - part number 44022AA123. The only difference is the rear axle back gasket. 13 -16 MY's use a 2 hole flange gasket and 2017+ use a compression style o-ring. Part number 44011CA000. I also recommend getting new a spring bolt kit as yours are probably going to be a pain, and possibly destroyed. This is the one I went with. OEM part numbers are in the listing : https://www.ebay.com/itm/363394557705
2.2Lude is offline   Reply With Quote
2018 manual trans into 2013 car? yfz450chuck Engine, Exhaust, Transmission 2 08-30-2020 02:25 PM
2013 vs 2018 FA20 SPCorBUST Engine Swaps 2 07-25-2020 08:30 PM
2018 BRZ cluster on 2013 gt86 (RHD -> LHD) yangsik777 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-29-2020 08:48 AM
2018 and 2013 axles interchangable? msaikhan Issues | Warranty | Recalls / TSB 3 03-07-2020 04:32 PM
2013 wheels on a 2018 with PP enivid Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-24-2018 09:48 AM
