Old 03-14-2024, 09:45 AM   #1
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Washer Fluid Spray - Low Flow
I feel stupid for posting this but the solution is escaping me.
Running the washer on the windshield results in a spray that's about 6" or so out the nozzles.
I've blown out the lines and cleaned them with vinegar/distilled water. The spray using that level seems to be fine.
I've replaced the factory washer pump with a Trico aftermarket pump.
The results are the same. The spray is the same out of each side.
What am I missing?
RT-BRZ is offline   Reply With Quote
Old 03-14-2024, 11:24 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you taken a pin to the nozzle heads yet? I used to see people have crystalized buildup from Rain-X orange fluid in the mid 2000s that you'd have to clear annually using a pin
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following User Says Thank You to DarkPira7e For This Useful Post:
Ultramaroon (03-16-2024)
Old 03-14-2024, 11:46 AM   #3
RT-BRZ
RT-BRZ's Avatar
That's literally the only thing I haven't done. I have the cowl off the car and I've continued to test it and nothing seems to change.
Honestly, it almost seems like the pump isn't making enough pressure but I'll try the pin idea next.
Washer fluid not spraying out btan219 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 09-16-2019 05:35 PM
Washer fluid fill Andrew025 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 07-02-2017 12:13 AM
Washer fluid tank, need to fix asap. SavingManuals Electronics | Audio | NAV | Infotainment 0 11-22-2015 06:12 PM
Washer Fluid Indicator Tdot BRZ First-Gen (2012+) — General Topics 58 02-19-2013 04:02 PM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 04:18 PM
