Drives: 2016 Scion FRS Release Series 2#439
75W140 Motul Gear Oil
Any of you track addicts running 75W140 in your Diff or Tranny?
Winter maintenance time here and considering this upgrade if appropriate for my occasional cruise - lapping toy.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
btr.life
Drives: 2022 GR86
Yes, I use it in the diff because I track a lot. I cooked the 75w90 fluid.
Sent from my SM-S926U1 using Tapatalk
Drives: None
I'm also using it in my diff right now since it is compatible with OSGiken.
Drives: Toyota GT86
Did you see any noticeable differences in the way the stock diff worked when you switched to the heavier weight oil ?
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#5 | |
btr.life
Drives: 2022 GR86
| The Following User Says Thank You to justinco For This Useful Post: | autoracer86 (02-13-2024) |
Drives: 01 911 Turbo, 03 G500
I run it but my car is used mostly on track. Local shop put it in, because I think there is no Motul 75-90 around or because they had found it worked a bit better in one of their shop cars. No complaints but doesn't behave any differently. I don't have a diff temp sensor though so no idea if its helping with temps.
#7 | |
Drives: Toyota GT86
Having said all that the bottle does say COMPETITION on it so....
#8 | |
#9 | |
| Motul Gear need additives? | ChrisP | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 11-06-2015 03:35 PM |
| Where to buy Motul 300 gear oil in GTA? | nocwage | CANADA | 6 | 08-25-2014 07:39 AM |
| Where to get Motul Gear 300 in the GTA? | automatic | CANADA | 5 | 04-09-2014 04:48 PM |
| No Motul Gear 300?? | markmatley | Hawaii | 14 | 04-17-2013 08:59 PM |
