Old 02-04-2024, 09:12 PM   #1
tbarantr
[sold] Raceseng Front Caster+Camber plates; SPL rear LCA; McGard lug nut and lock kit
Located in the Bay Area and only looking for local pick-up for now.
1. Raceseng Front Caster+Camber (cascam) plates for 1st gen brz/86, with the following
0922 M12 x 1.25mm Shock Nut
09252 15mm Spring Perch Bushing
09204 90mm Spring Perch
Installed on 02/18/2020 and uninstalled on 12/01/2020. Since then the plates have been sitting in the garage because I never got a chance to write this post up.
It should be around 8k miles including 4 track days.
$390 OBO.
2. SPL Adjustable Lower Control Arms (Rear) for 1st gen brz
Installed on 02/18/2020 and uninstalled on 02/28/2022. Since then the LCAs have been sitting in the garage because I never got a chance to write this post up.
It should be around 11k miles including 9 track days.
$450 OBO.
3. McGard Splinedrive 65554 lug nut and lock install kit (specs as shown in the pictures)
$50 OBO.
tbarantr is offline
Old 02-10-2024, 10:10 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’d buy this all if you considered shipping.
NoHaveMSG is offline
Old 02-19-2024, 03:17 AM   #3
tbarantr
All sold.
tbarantr is offline
Sold: Raceseng Front Caster+Camber plates and Vorshlag Rear Spherical Shock Mounts TMF Brakes, Suspension, Chassis 3 05-04-2021 01:50 PM
SOLD: Raceseng caster + camber - adjustable front camber plates higrip Brakes, Suspension, Chassis 4 09-17-2019 01:43 PM
>>SOLD<< RACESENG Adjustable FRONT CAMBER + CASTER Strut Mount Plates Lightened Brakes, Suspension, Chassis 7 09-16-2019 03:09 PM
FS: Raceseng Caster/Camber Plates Deraj Brakes, Suspension, Chassis 3 06-28-2017 12:52 PM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 05:34 PM
