Drives: Subaru BRZ
Control arms and toe arms
Hello everyone! I just want to ask if this LVTU adjustable lower control arm and toe arms are worth running? Any one here rocking these and what are your insights about this product?
Thanks! |
Drives: Crapcan
What are you trying to do with the car, how low are you from stock ?
Drives: Subaru BRZ
I'm trying to add some negative camber. I'm on KW v1 coilover
#4 | ||
LMGTFY
Drives: 13 FRS, 91 Miata
And if that's the case. Get what ever you want it doesn't matter if all its going to see is normal driving and hardparking. |
Drives: Crapcan
Standard height on those should net you around -2 rear. Well within the range of the stock toe links too. Some cars have issues with uneven camber side to side but chances are you are probably fine on stock parts.
Drives: 2017 BRZ PP, 2004 WRX
I'm skeptical of no-name brand parts like this. Hell, I've even seen Verus Engineering lower control arms snap at the attachment points when under autocross loads.
I'd go with SPC RLCAs and call it a day. They just work and have a different adjustment system then most other aftermarket ones that thread in. You probably don't need toe arms.
| Parts Shop Max (PBM) adjustable rear lower control arms & toe arms FS | frs_adrian | Brakes, Suspension, Chassis | 1 | 04-29-2023 03:45 PM |
| wanted: rear control arms, toe arms & trailing arms | Turbo | Canada Classifieds | 0 | 08-14-2018 12:18 AM |
| Need to buy: stock rear lower control arms/toe arms and intake elbow | CoolHandMoss | Want-To-Buy Requests | 6 | 07-12-2018 08:44 AM |
