Old 10-21-2023, 10:31 AM   #1
WNDSRFR
Drives: FR-S,GTI
Clutch release fork
I need to pull my transmission again and want to change the fork while I'm at it. Does anyone know if 30531AA220 and SU003-00803 are exactly the same part? I think one is the Subaru part and the other is the Toyota part. Last time I used the SU003....but I couldn't find it so I got the 305.....
And no, I don't want to get the Cusco or Versus because they cost 5 times as much and my car has 240,000 miles on it. So I hope that a new OEM fork will last the life of the car. Or at least the life of the next TOB.
Old 10-26-2023, 08:58 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
should be same since it's same car
I agree with you on getting OEM since your car is 240,000 miles
Old 10-26-2023, 09:07 AM   #3
Code Monkey
Drives: Subaru BRZ
I have like 3 OEM forks in the garage, can send you one at no charge if you are still looking for one.
Code Monkey is offline   Reply With Quote
Old 10-26-2023, 10:12 AM   #4
WNDSRFR
Drives: FR-S,GTI
Thanks for the offer but I already have the Subaru fork.
The problem I'm having this time is actually the clutch disk itself is starting to slip under heavy load. The first time it was the TOB. I was young and dumb and replaced everything.
The clutch was perfectly good but I already had a stage two kit and installed it. Went back together with few problems.
The second time was for the TOB again. Replaced the TOB and quill. Took a couple days and many bad words to get it back together.
The third time was for the clutch fork (broke). Replaced the fork and TOB but should have done the clutch too, but I didn't want any complications because it was so hard to get it back together the last time. Got lucky and it slid back together.
So recently I replaced the batteries in the ESC and when I engage it in sixth gear the clutch slips. But at least the car is still drivable, not like the last three times.
So, this time I can do the job on my terms, and take my time.
Old 11-03-2023, 01:43 AM   #5
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Man this is wild to me because it's so easy to replace the clutch/pressure plate once you have the transmission dropped.
demasrv is offline   Reply With Quote
Old 11-03-2023, 05:49 AM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Same part, but find you pay Subaru tax almost every time. Packaging is identical minus a Toyota sticker slapped on-top.
Ordered rear main seal and new clip/spring for clutch fork, Subaru wanting something like $75, Toyota was $32 lol..
Old 11-03-2023, 10:20 AM   #7
WNDSRFR
Drives: FR-S,GTI
I agree it is easy. But it was in the middle of August and it was 96 degrees every day with 90 percent humidity and I just wanted my car running again as soon as possible.
Old 11-03-2023, 10:22 AM   #8
WNDSRFR
Drives: FR-S,GTI
In this case the Subaru part was actually cheaper than the Toyota part.
SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB zc06_kisstherain Transmission and Driveline 3 10-17-2018 10:31 PM
[SOLD!] FS: NEW Diftech Heavy Duty Clutch Fork + Versus Clutch Fork Pivot reeves Transmission and Driveline 2 08-25-2018 12:18 AM
Clutch Fork Failure - i.e. New Clutch and Tranny BuzzR Engine, Exhaust, Transmission 11 06-22-2018 02:53 AM
▀▄▀▄ Vivid Racing | Cusco 86/BRZ Clutch Release Fork and Pivot Set vividracing Transmission and Driveline 0 07-12-2016 01:32 PM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
