Old 09-17-2023, 04:50 PM   #1
OfficeLinebacker
Drives: 2019 Toyota 86 Base AT
Question What are the best standalone thermostatic oil sandwich plates for oil coolers?
The internal threads in my mocal are stripped so I need a new sandwich plate.
The Greddy looks good but I'd rather be able to use the OEM filter than have to source a special filter to change oil.
I like the 45 degree angle adapters for the oil lines because it makes it much easier to clear the air box.
I'd also like a higher set point for the thermostat since it's a daily driver and I'd rather not block off the grill in the winter
Any other suggestions? Thanks in advance!
OfficeLinebacker is offline   Reply With Quote
Old 09-17-2023, 05:14 PM   #2
Ashikabi
Ashikabi's Avatar
This one doesn't have a 45 degree adapter but the price and quality are good. Uses stock oil filters
https://www.savageautoworks.shop/pro...e-adapter-an10
Sent from my KB2007 using Tapatalk
Old 09-20-2023, 02:21 PM   #3
gnarjunkie
Drives: '23 GR86, '17 BRZ
Setrab one is nice and you can swap out the fittings to 45 degree ones.
Personally I like that more than the Greddy style, those ones just seem like they wouldn't flow as well having ports that are capped at the ends.
I know Mocal used to make a plate that opened at 200F, but I'm not sure if it's still around. Regardless, even when I had the 200F version, I had to block off the cooler in the winter. You'll always get some oil flow through the lines and I still found it hard to get up to proper temp with the cooler uncovered.
It's incredibly easy though... I just went and bought a thin $1 plastic cutting board from Walmart, trimmed it to the size of the cooler, and ziptied it on. Lasted multiple winters and worked very well even once I went to a 180F thermostat.
gnarjunkie is offline   Reply With Quote
Old 09-20-2023, 05:47 PM   #4
Jdmjunkie
Drives: Scion FR-S 10 Series
Somebody on this forum mentioned a aeronautical company that has a thermostat valve the will allow no flow when cold to recirculate oil until it is warm. This is unlike automotive designs that still allow some oil through even when cold. I would love to see an application like that for our cars.
Jdmjunkie is offline   Reply With Quote
Old 09-27-2023, 07:34 PM   #5
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Most Companies offer a thermostatic adapter. I have the Jackson Racing kit and I like it. It is also Thermostatic and uses the stock filter.
JDMChris is offline   Reply With Quote
Old 09-27-2023, 09:29 PM   #6
Jdmjunkie
Yes I understand that, but this one was different. When below the threshold of temperature it was fully closed so the oil didn't even go through the cooler. It looped back to the engine.
Old 09-29-2023, 08:39 PM   #7
That's a great way for cold oil to hit hot components, when the plate does open.
Thermal shock is not your friend.
Old 10-03-2023, 10:02 AM   #8
Grady
Grady's Avatar
Oil takes the least path of resistance. When in bypass mode there is little to no oil that will flow through the cooler. In fact just the opposite on certain aircraft piston engine oil coolers. They always force some oil through the cooler. if not the oil would get to cold in the cooler and not flow when needed.
oil cooler, sandwich plate, thermostat
Mishimoto Oil Cooler with mishimoto thermostatic sandwich plate. SOLD Tuxedo Tony Canada Classifieds 7 02-23-2021 10:02 PM
Mocal oil cooler/thermostatic sandwich plate CoolHandMoss Engine, Exhaust, Bolt-Ons 2 05-29-2020 11:54 AM
FS: Derale Thermostatic Sandwich plate. New in box CoolHandMoss Engine, Exhaust, Bolt-Ons 0 05-27-2020 04:54 PM
Mocal Oil Cooler Thermostatic Sandwich Plate FS pgranberg11 Engine, Exhaust, Bolt-Ons 2 05-17-2018 12:10 PM
Mishimoto Thermostatic oil sandwich plate mtsound Engine, Exhaust, Bolt-Ons 2 08-23-2017 04:36 PM
