Drives: 2019 BRZ
Godspeed brand rear control arms
Please reply if you have used them. Upper or lower rear control arms. What is your experience ?
Drives: 2017 BRZ PP, 2004 WRX
I wouldn't run "Godspeed" anything on my car, but that's just me. Back in the day, I'd run a lot of off brand parts because I was cheap and many things just didn't work or fit well. I got over that and normally get more name brand parts that have a reputation. Really helps with fitment and headaches.
With that said, the Godspeed ones only adjust toe, not camber. And if you're getting real lower control arms, the advantage here is getting that camber adjustment. From the factory, you can adjust toe already. I'd skip the Godspeed ones for that reason alone. If you just need something cheap, but works, get SPC.
Drives: 2013 Subaru BRZ Turbo
Just spend a few bucks more and get these: https://whitelineperformance.com/pro...-arm-lower-arm
For anything with a pillowball or spherical rod ends, quality is pretty important. A brand known for using quality components is well worth it.
For anything with a polyeurathane bushing for a moving joint...well...be extra extra careful in general. - Andrew |
| wanted: rear control arms, toe arms & trailing arms | Turbo | Canada Classifieds | 0 | 08-14-2018 12:18 AM |
| Megan racing rear lower control arms , toe arms, rear traction arm | fcdrifter20 | Brakes, Suspension, Chassis | 11 | 01-03-2016 08:11 PM |
| FS: Agency Power Rear Lower Control Arms (Brand New In Box) | Adeel | Brakes, Suspension, Chassis | 1 | 05-14-2014 05:50 PM |
| SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout | quiet-k | Brakes, Suspension, Chassis | 8 | 03-22-2014 10:17 PM |
