Old 07-13-2023, 07:40 PM   #1
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Installed rear cosmetic diffuser. Need constructive criticism.
Hi!
Finally reinstalled new cosmetic diffuser from Ikon Motorsports. It’s gloss black. Originally, I installed unpainted one, but the pop in clips that held it finally gave out and due to my fear of drilling into bumper, I never did corners. Play stupid games, win stupid prices, I lost it after an event where it loosened up due to high stress. I hope it didn’t fall off on highway.
Queue today, received new diffuser in gloss. Unfortunately, I was not sure how to screw/drill using equipment that came with it so ended up using only half the stuff that came with diffuser. 3 screws to hold middle portion (made sure they are reinforced) and heavy duty zip ties on rest+drilled holes on corners for more zip ties. Its very sturdy this time, no shake, my bumper itself is even more solid.
What could I have improved on in this set up? Attached are few pics of the new booty.
Cheers.
Packofcrows is offline   Reply With Quote
Old 07-13-2023, 09:29 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Some zip ties get stiff and break over time and exposure (years). Good call using three in each point. Keep checking over time. Replace all if one breaks.
Old 07-14-2023, 07:39 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
looks good! now time to change the exhaust tips to something that doesn't look like it got smashed on a parking block!
typically, that's the white zipties, as black versions are typically rated for UV and some heat exposure.
Old 07-14-2023, 09:04 PM   #4
Ultramaroon
not playing cards
I've wondered about that! I can only recall white ones ever breaking but never really dug into it.
Old 07-14-2023, 09:30 PM   #5
Packofcrows
They just need some <3.
I stopped by autozone for some Eagle One Never Dull metal polish. Just need elbow grease now.
Old 07-14-2023, 10:44 PM   #6
Teseo
Drives: frs
Use Mothers polish drill bit (conic or ball red foam) for faster and better results. Than boots need 4th brake light. Is affordable cosmetic mod
Old 07-15-2023, 03:25 AM   #7
Packofcrows
For sures! I want the Valenti w/ rear fog light mode, but I’ve already spent way too much on repairs and maintenance. CHP pulled me over bit ago, guy was super friendly. He commented that my passenger side fog light was out and then gave me a wink after commenting on car. Got home and now in process of this:
They way more yellow than picture. SS3 S
All done. Fixed so many electric issues. Time to sleep.
Not worrying about grill unless it begins to fall off. Will just buy new one since mine has broken and cracked tabs
Double checked diffuser. Thing is very sturdy. Now need a protective lip that looks oem.
Old 07-15-2023, 08:15 AM   #8
soundman98
soundman98's Avatar
yep. i grew up only having the white one's around, and they'd always break after a few months. somewhere around the time i started driving and taking 'shopping trips' walking around at home depot by myself, i was finally able to see a new package of zipties that still had the label on it.
that was where i learned that there's a plastic-type difference. been using mostly black zipties since with very few failures outside of structural situations that shouldn't have been done in the first place. and they normally end up looking better in most cases anyways
Old 07-15-2023, 08:18 AM   #9
soundman98
soundman98's Avatar
follow up the metal polish with some wax of your preference. most polishes will bring back dulled chrome/metal surfaces, but aren't really designed for long term protection, so you'll be back to re-polishing them in another week or two.
the wax should make the work you did hold up for at least a few months, depending on how much water/grit stuff you're driving through, and how much you drive the car.
Frameless rear view mirror, cosmetic issue? kch Issues | Warranty | Recalls / TSB 11 08-14-2017 01:25 PM
Anybody got the OEM-style rear diffuser and rear quadrants installed together? trinxified Cosmetic Modification (Interior/Exterior/Lighting) 12 08-14-2014 01:29 AM
Pics of tamon rear diffuser installed? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 0 07-01-2014 11:51 PM
Constructive critizism for my build... ravenblackfrs Electronics | Audio | NAV | Infotainment 9 11-15-2013 12:28 AM
FR-S with BRZ diffuser...I installed it. Supermassive Cosmetic Modification (Interior/Exterior/Lighting) 21 08-02-2012 11:15 AM
