Old 06-30-2023, 08:46 PM   #1
casselarc
Drives: 2013 Scion FRS
Question Perrin air intake
I put a new Perrin air intake (not the cold air intake) on my 2013 FRS with 42k miles and I got a check engine light. I pulled the codes and it's telling me the fuel is too lean, rich, or a fuel injector issue. Has anyone had this problem? Do I need to disconnect the ECU when I install it? I have ordered a open flash tablet to tune it, would that help? Thanks so much.
casselarc is offline   Reply With Quote
Old 06-30-2023, 10:48 PM   #2
Teseo
Drives: frs
You mean the Inlet hose ( it connects to the throttle body) ? If so double check the MAF connection wiring harness and double check everything
Old 06-30-2023, 11:22 PM   #3
casselarc
Yes, the inlet hose. Thank you, I will do that tomorrow
Old 07-01-2023, 07:42 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Make sure you did not overtighten the connection to your airbox. If you crushed the plastic bit you might have a leak.
Old 07-01-2023, 11:29 AM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My guess is it's leaking somewhere. You shouldn't need a tune to keep the fuel trims within acceptable values with just the inlet pipe. Do you have an aftermarket filter or air box?
I would also make sure the inlet isn't rubbing on the accessory belt, that can wear through if it's bad enough. Probably not the problem now since it is new, but just something to take note of.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 07-01-2023, 08:47 PM   #6
casselarc
I put a K&N filter where the OEM one should be. I saw that the inlet hose is really close to the belt, so I made sure that is is far enough away. My next question is how would I find a leak?
Old 07-01-2023, 09:07 PM   #7
Grady
Grady's Avatar
Take it apart again and inspect everything, Cracks, buckles, loose connections ect. There are 2 connections between the MAF and the throttle body. Should not be hard to find.
Old 07-01-2023, 09:08 PM   #8
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
One easy way is to get some carb cleaner and spray around any connection points. If the idle changes and revs up a bit, there's your leak.
It evaporates rather quickly, so it doesn't make a mess and is formulated to be burned in an engine.
cmiovino is offline   Reply With Quote
Old 07-01-2023, 10:31 PM   #9
Spuds
The Dictater
Spuds's Avatar
Oiled filter? MAF cleaner is your new best friend.
Also, some aftermarket filters in the stock air box can be unintuitively tricky. Make sure the two tabs on the sides of the air box are underneath the bracket, not to either side of the bracket. Pics below show correct installation.
Other than that, just make sure both band clamps on the inlet hose are seated completely around the pipes the hose connects to. If the bottom is kicked out a bit, the hose won't seal.
Old 07-02-2023, 09:51 AM   #10
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Check the crank case vent hose too.
Old 07-02-2023, 10:04 AM   #11
Teseo
Drives: frs
Mine is not sealed like that with the k&n and never have check in light... maybe OP have something wrong
Old 07-02-2023, 10:37 AM   #12
casselarc
Thank you all so much for your help! I will get out there today and fix it. Thanks again!
Old 07-06-2023, 03:00 PM   #13
Spuds
The Dictater
Spuds's Avatar
Did you find a solution?
Old 07-07-2023, 10:18 PM   #14
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
The perrin intake is one of thoes that drastically changes the maf reading, and you need a tune to compensate.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Perrin Intake, Perrin Crank Pulley (red) and Rev Works UEL Header Dave-ROR Engine, Exhaust, Bolt-Ons 11 02-14-2020 01:58 PM
FS: Perrin Exhaust, Perrin Intake, Green Air Filter, Fumoto Valve Scoobnut 555 Engine, Exhaust, Bolt-Ons 13 03-29-2017 01:51 PM
Perrin Cold Air intake CAI (black) and AVO silicone intake tube (blue) Joesurf79 Engine, Exhaust, Bolt-Ons 13 07-29-2016 02:38 PM
SOLD - Perrin Cold Air Intake w/Perrin silicone elbow killswitch Engine, Exhaust, Bolt-Ons 4 10-04-2015 01:32 AM
