Old 06-27-2023, 02:59 PM   #1
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Header Shield
Hello again.
Haven't been here for a while. As some of you already know, I installed the greddy circuit spec headers some time ago. Well, I have read that the OEM shield can be installed. What is the function of the shield? Do you recommend that I install it?
Thank you
Alastor is offline   Reply With Quote
Old 06-28-2023, 03:28 PM   #2
humfrz
I would guess that it is to help protect parts engine from heat from the header.
Old 06-29-2023, 08:51 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Instead of the heat shields, you could wrap the header. Although, some manufactures don't recommend it. Ceramic coating is another option. I used Swain Tech White Lighting. It's tough stuff.
https://swaintech.com/race-coatings/...aust-coatings/
Old 06-29-2023, 12:51 PM   #4
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
The OEM header shields are meant to protect other components to heat and also protect against from fire if you park on dry grass on leaves... but also, there's the undertrays there, so this was more of a thing in the past when we didn't have those on most cars.
If the OEM ones just bolt over to the new header, there's no reason not to use them if you don't plan on doing a wrap or ceramic coating. Most headers are of a different design and they don't bolt over. I've actually never heard of an aftermarket header fitting the OEM heat shields, so double check this. I think there would be at least an chance they rattle taking them on and off, things not mating up 100%, etc.
Wraps used to be a thing more in the past because it looked cool and got the job done. However, if it gets coated with oil in the long run, there's a small chance of fire if it ignites.
Ceramic coatings are the new thing, but generally you can't apply these yourself and cost $150-300 for the size of our headers. Quite steep when you factor in it's just a coating and wrap might only cost $50 all said and done.
Personally I don't know what I'm going to do when I get a set of UELs myself. I'm leaning away from wrapping as once it's wrapped, if you want to change it out, you're going to have to remove it to redo it. Ceramic coat is expensive.... so yeah. I likely won't get one that the OEM heat shields attach.
There's likely some very very slight power loss from not using a proper ceramic coating relating to the exhaust gases exiting as easily as possible. Maybe. I also really don't think there's a major heat issue. The bottom covers protect against fire and the heat radiation to other parts of the car might come into play with slightly higher oil temps as the header is near the oil pan.
If your OEM metal ones fit, I'd go with those if you aren't chasing every single HP in some time attack / track setting.
cmiovino is offline   Reply With Quote
Old 07-05-2023, 07:58 AM   #5
Alastor
Alastor's Avatar
Thanks a lot. i think that i will to install shield.
Header ceramic coat or heat shield wrap? Phuviano Engine, Exhaust, Transmission 20 11-02-2019 02:05 AM
Anyone know the typical temps on the OEM header heat shield? canyons Engine, Exhaust, Transmission 5 08-07-2019 04:24 PM
OFT + Gruppe S UEL header with heat shield, Berk front pipe Smough Engine, Exhaust, Bolt-Ons 8 05-11-2017 02:17 PM
OEM Sun Shield (SOLD) u/Josh Interior Parts (Incl. Lighting) 1 12-09-2015 02:28 AM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
