Old 06-08-2023, 06:16 PM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Battery power draw
Hi everyone,
My battery seems to keep dying on me quite often. I measured the power draw with an amp meter that, upon connection, shows 200+ma of power draw and then slowly drops over a minute or two to eventually stabilize around 40-45ma draw.
Is this a normal value? Or should I further investigate what's using power when the car is shut off?
BR,
Alex
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
humfrz (06-10-2023)
Old 06-08-2023, 06:44 PM   #2
Ashikabi
Ashikabi's Avatar
40 is pretty normal. How old is battery? Is the alternator working properly?
Sent from my KB2007 using Tapatalk
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
NoHaveMSG (06-09-2023), soundman98 (06-08-2023)
Old 06-09-2023, 08:33 AM   #3
alex87f
Meow
alex87f's Avatar
Battery's 3 years old. It's a namebrand 60Ah one so it should do OK.
Alternator is showing 14+ volts under charge so that seems OK. But whenever I leave the car to sit for over 2-3 weeks, it won't crank. I can hear the starter click, but that's it.
Either I'm not reading the right draw values, or my battery doesn't have the advertised capacity anymore, 60Ah should last me two months with a 40ma draw.
Old 06-09-2023, 08:59 AM   #4
Ashikabi
Ashikabi's Avatar
Car needs significant amperage to crank. Any modern car will do the same if you leave it for 2 weeks. You need to disconnect the battery or use a trickle charger. Unless there was a typo, the problem you are describing isn't actually a "problem"
The Following User Says Thank You to Ashikabi For This Useful Post:
humfrz (06-10-2023)
Old 06-10-2023, 08:45 PM   #5
humfrz
Hi everyone,
BR,
Alex
If you have not already done so, I suggest you check the fluid level in the battery. Also, clean the battery posts.
Also, you may want to have the battery load tested to see if it has a weak cell.
My 9 year old battery seems to get lazy every few months, so, I zap it with a battery charger for a few hours and that seems to perk it up for a few months. I only drive my car for about a dozen miles 2-3 times a week.
soundman98 (06-10-2023), Ultramaroon (06-11-2023)
Old 06-11-2023, 02:42 AM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Time to start logging some more seat time, hum.
Originally Posted by humfrz
I'm old and lazy
humfrz (06-18-2023)
Old 06-18-2023, 04:11 PM   #7
humfrz
Ya, I hear ya.
Some advice for you younger drivers, if you're going to plan some serious seat time in a FRS, do it before you reach 80 years old -
Clipdat (06-18-2023)
Dead battery - OBD-II power and cigarette lighter power? lapsio BRZ First-Gen (2012+) — General Topics 10 04-08-2021 08:22 AM
Won't start, new battery, no power sync32 Issues | Warranty | Recalls / TSB 5 02-07-2021 10:16 AM
OBD Power draw when car is off CSkap21 Electronics | Audio | NAV | Infotainment 1 03-07-2019 07:17 PM
OBD power draw? alex87f Software Tuning 6 12-30-2018 11:49 AM
How much extra power can I draw from the fuseboxes? Achilles Electronics | Audio | NAV | Infotainment 6 12-16-2014 03:17 AM
