Old 05-23-2023, 02:09 PM   #1
tazio
Drives: Don't yet have a Toyobaru
How many miles does it take for RTV to get into the oil? Any change on later engines?
When removing the oil pan requires removing an aero panel, removing the headers, and using a pry-bar and the pickup filter is at the top of the tube, the job is a pain in the ass for a shade-tree DIYer. And while Killer B made that pre-filter, you'd have to take it off again, if you ever need to take the car to the dealer.
tazio is offline   Reply With Quote
Old 05-23-2023, 10:08 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
How long is a piece of string? It may never happen or it may happen within 500mls
Also why would you need to remove the Killer B filter when going to the dealer? Only reason I could see is if their filter didn't do its job at keeping the silicon out.
1974 TA22 Celica
2013 86 GT
Old 05-23-2023, 11:34 PM   #3
tazio
Well, is there any data on it?
An aftermarket pre-filter might be justification to void your warranty.
Old 05-24-2023, 12:37 AM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
lol. And they might "void your warranty" (hate that term) if the engine is completely stock!
It's Subaru we're talking about here after all.
Originally Posted by humfrz
I'm old and lazy
Old 05-24-2023, 03:31 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
All the upgrades are just feeding off of hysteria. RTV in the pan is merely a symptom related to grenaded engines, not the primary cause.
The main problem is RTV getting loose in the engine from wherever there is a joint sealed with RTV. All the RTV that made it into your oil pan is good: that's the RTV that didn't cause a problem. It's the RTV that never makes it to the oil pan that causes engines to blow up, and you will never know about that unless, well, your engine blows up or you rip the engine apart and look for shards in every nook and cranny.
I think it's been shown generally that it takes quite a bit of pick-up blockage to meaningfully really constrict oil flow. All you need to do to remedy that is clean up what's already there and put it back if you're worried about that. Any RTV that makes it past the pick-up screen gets shredded up by the oil pump and then captured at the filter.
EndlessAzure is offline   Reply With Quote
Old 05-24-2023, 12:26 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Why hasn't SOA done anything about this yet, or even acknowledged it?
Hell, they did a fake ass bogus bullshit nationwide valve spring recall that they didn't need to do (that ironically caused similar issues with RTV ingestion/circulation due to excessive amounts used by techs during the conclusion of the 14 hour engine-out re-assembly process), but they won't take action on this?
Fucking Subaru. Fix your shit.
I'm old and lazy
Old 05-26-2023, 12:17 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
Despite being a top enthusiast talking point, I doubt this makes jd power ratings top 500 talking points
Old 05-26-2023, 01:16 PM   #8
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Because SOA is complete dogshit. Customer service is clearly something they cost cut.
Breadman is offline   Reply With Quote
Old 05-26-2023, 05:21 PM   #9
soundman98
soundman98's Avatar
i already responded to this comment elsewhere, but if you keep parroting this, i'll keep parroting my response.
the recall wasn't fake, or bogus.
the recall was specifically because the metal supplier that supplied the valve spring metal was caught falsifying certification data for multiple years of their relationship with subaru. this specifically means that subaru had no idea what metal was used for the valve springs during those years. it could've been a better material, or it could've been recycled tin cans.
their engineers specifically came up with a technical specification for the metallurgy required for the component, and subaru offers a warranty for products they create based on those technical specifications.
by receiving and distributing components of an unknown makeup, subaru can't know the reliability and performance of those components, which can lead to engine failure.
so they did what any reasonable company does, and issued a recall for the years of the falsified data to ensure that the product they sold and warrantied met their minimum product specifications. it also covers their butt in any liability issues, as they are both offering a fix to make the consumer whole, and also making it clear to other suppliers that they won't further the same material falsification issue that lead to the recall in the first place.
Old 05-26-2023, 05:22 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Maybe it didn't chap your ass as much because you don't live in California where is was mandatory or else you can't register the car anymore.
If it was optional for me and I could have declined it, I would've had much less of a problem with it.
I'm old and lazy
Old 05-26-2023, 06:04 PM   #11
soundman98
soundman98's Avatar
i just wouldn't have registered the car for a year until all the techs worked out the bugs in doing it.
Old 05-26-2023, 06:07 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
So just register your only vehicle as non-op, but continue to actually daily drive it for commuting to work?
I'm old and lazy
Old 05-26-2023, 09:16 PM   #13
soundman98
soundman98's Avatar
Who said anything about that? I never got the renewal notice!
How many miles FA20 engines can survive with track use? lapsio BRZ First-Gen (2012+) — General Topics 31 12-13-2022 04:44 PM
10k miles between oil change 8RZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 03-27-2018 08:29 AM
how many miles before first oil change Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 72 10-25-2014 10:35 AM
Oil change at 4100 miles djdrugga24 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 03-28-2014 02:00 PM
Oil change at 1000 miles. Dorb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 03-08-2013 04:18 PM
