Old 05-16-2023, 04:11 PM   #1
Shambosley
Shambosley's Avatar
Strange rocking and knocking coming from rear of car
So I've been searching everywhere to find someone with the same problem which leads me here to the professionals.
What's happening is, if I accelerate hard from a stop, something feels like it's rocking from side to side in the rear end followed by a "knock, knock, knock" back there and almost as if it follows the driveshaft to the front because there will be a tiny squeak in the front sometimes when this does happens. Only does it when taking off hard but has done it when stopped on a hill and applying torque to the rear end when taking off.
This all started after trying to do a little burnout forgetting about TC being on, since it's my first car with it, and I heard a pop in the back. Continued to drive home and nothing seemed wrong until I realized what it took to bring the problem to the surface
Im not very technical with all the parts of a car, but jacked up the rear end on the diff and checked u joint in the middle as well as where the driveshaft mounts to the diff and where the input splines go into the tranny. Everything was tight with no play other than a tiny bit in the middle at the DS carrier brace.
Not sure what to really check when under there or which bushings to check but i did notice one of the rear diff bushings is cracked a little and found a strange fluid on the side of the gasstank across from what I believe to be the subframe bushings shown in attachment. This fluid is on both front bushings of the rear subframe
https://youtube.com/shorts/vtjK2RqjQVc?feature=share
Wish I knew how to mount some sort of camera under there to resimulate and capture the problem, so I tried to be as descriptive as possible. Any help is much appreciated
Shambosley is offline   Reply With Quote
Old 05-16-2023, 04:44 PM   #2
strat61caster
strat61caster's Avatar
Describe the rocking more please, like there’s an item moving or like the whole car is shifting?
If it’s less of a knock and more like a tick I’m going to guess it’s time for new axle nuts.
If you take it to an alignment shop they can hopefully diagnose and tighten something that’s loose as part of a standard alignment.
I’ve dumped the clutch hundreds of times, I doubt you broke anything and more likely something has just shaken loose on a 10+ year old car. Don’t forget to check the interior of the car for any items rolling around behind your seats or in the trunk.
ineedyourdiddly
Old 05-16-2023, 06:00 PM   #3
Shambosley
Shambosley's Avatar
I sure wish it was something as simple as axle nuts but something is definitely moving underneath. Feels like, from what I guess would be the whole driveshaft rocking underneath the car back and forth from right to left or left to right which makes a knock or banging sound in the rear until I ease off and let everything settle under there. Feel it only in the rear but it is accompanied by a tiny squeak in the front sometimes, which makes me feel like it's the drive shaft rocking.
I'll also hear that same squeak in the front only, if I go over a little hill where it's like the car is on two different planes(levels), like a motor mount squeaking or something.
Thanks for your reply
Old 05-16-2023, 10:38 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
Could you make a video of the noise?
1974 TA22 Celica
2013 86 GT
Old 05-17-2023, 12:05 PM   #5
Shambosley
Shambosley's Avatar
I'll see If I can figure out a way to capture a sound or video. I try not to let it happen if can, because I'm afraid something is gonna break lol
Also I'm not 100% sure it's originating in the back, kind of hard to tell. Motor could be moving and shaking the driveshaft back to the rear.
In the mean time, any recommendations on how to easily check the motor mounts on a manual?
Old 05-17-2023, 08:57 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would check the rear diff. almost sounds like it's come loose from it's mounting points.
but it would still be surprising that you managed that-- i just left t/c off today, got stuck in the wrong lane behind a surprise-left-turner. at that point i was irritated, and traffic wasn't easing.. i clutch-dumped 1st at about 5k, and then slammed/chirped 2nd at redline(i've learned that people don't mess with someone making obnoxious car noises, otherwise, i would've gotten honked at)... my car is still holding together fine...
Old 05-17-2023, 11:12 PM   #7
strat61caster
I’ve done that literally hundreds on times without issue.
ineedyourdiddly
Old 05-18-2023, 06:03 AM   #8
Shambosley
Shambosley's Avatar
Gotta say, I really love how optimistic you guys are here, I always assume the worst. I'll get under there start throwing a wrench to all the diff bolts.
Old 05-18-2023, 12:46 PM   #9
norcalpb
norcalpb's Avatar
How did you jack up the rear of the car? If it was by the diff, and it didn’t move, I’d say the bolts should be properly tightened.
A video would be really helpful. Almost sounds like when I had my busted transmission mount.
norcalpb is online now   Reply With Quote
Old 05-18-2023, 02:38 PM   #10
Shambosley
Shambosley's Avatar
I did jack it up by the diff and it didn't move. I actually just captured a video of the sound, what's the best method of sharing it here?
I checked the tranny mount to the best of my ability and nothing obvious stood out. I also have a white line tranny mount bushing that I have yet to put in. Maybe it's time so I can really get in there and see if anything is wrong there.
Old 05-19-2023, 09:20 AM   #11
Shambosley
Shambosley's Avatar
Old 05-19-2023, 06:36 PM   #12
Shambosley
Shambosley's Avatar
Also just noticed when I turn the AC on a here a knocking at the bottom of motor between motor and tranny. Think maybe a mount up there broke?
Old 05-21-2023, 11:34 AM   #13
Shambosley
Shambosley's Avatar
So I got under there today, specifically looking at the engine mounts and I've noticed that they are not mounted to the subframe, Is that normal? The mounts threaded bolts that go through the subframe don't have any nuts on either of them. Videos I've watched shows them removing a 14mm nut.
Old 05-21-2023, 11:41 AM   #14
soundman98
soundman98's Avatar
that would definitely cause a clunking sound!
Strange Knocking Noise From Transmission? Acanaceous Issues | Warranty | Recalls / TSB 10 03-25-2020 05:39 PM
GT86 - Strange Knocking Sound Emissary_of_Pain Issues | Warranty | Recalls / TSB 30 06-12-2019 04:35 AM
Strange humming(ish?) sound coming from near rear wheels when car is off redwing634 Issues | Warranty | Recalls / TSB 2 04-02-2017 06:42 PM
Rocking the RB rear diffuser without the rest of the kit pr0xy Cosmetic Modification (Interior/Exterior/Lighting) 0 07-06-2015 08:01 AM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 06:16 PM
