Old 05-05-2023, 07:58 AM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Largest tire that clears?
So I have been thinking about maybe turning my car into a rallycross brz next year and wondering what size tires have people stuffed under their car. Flatout coilovers can give me a 2" lift and Falken has a few wild peaks that are 26.3"-27.2" tall. With a lift I can probably stuff them under. I currently drive around with 255/40/17s. Shockingly info is rather hard to find on this.
Thinking about trying a 235/55/17 or 215/60/17.
Breadman is offline   Reply With Quote
Old 05-06-2023, 03:18 PM   #2
lapsio
lapsio's Avatar
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
I honestly think that at this point wheel arch depth will be the biggest offender. Height shouldn't be much of a problem since like you said you can adjust suspension height and stiffness to compensate but I believe you could get into rubbing issues at full lock simply because arches may not be wide enough to fit bigger, rotated wheel. It could probably be mitigated by adjusting max steering limits. Kind of opposite to what you do for drift with angle kits. Fenders can be replaced with widebody variants, which also might be necessary to provide more space for everything.
There are people using 19" wheels on BRZ so idk... I believe it should be doable but might not be as straightforward. You could probably mock some test dummy by putting cardboard cutouts in size of 26.3" on your existing wheels and see whether it rubs somewhere at full lock.
lapsio is offline   Reply With Quote
Old 05-06-2023, 10:59 PM   #3
SCFD
Go through the rally/off-road thread. Here's some links:
https://www.ft86club.com/forums/show...&postcount=110
https://www.ft86club.com/forums/show...&postcount=112
https://www.ft86club.com/forums/show...4&postcount=86
https://www.ft86club.com/forums/show...0&postcount=63
SCFD is offline   Reply With Quote
Largest tire for stock suspension? Razorlor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-23-2018 06:43 PM
Largest tire on stock rims woodchip Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-18-2018 10:29 PM
Largest tire size on stock rims? Liquidsnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-20-2015 11:05 PM
WTB: Strut bar that clears the BPBs YEAHdams Brakes, Suspension, Chassis 0 07-30-2014 01:28 AM
largest tire for 19x8.5 et45 garfull Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-24-2013 11:44 PM
