Drives: 2023 BRZ MT Sport Tech Black
2023 New BRZ, 1st Oil Change, No Crush Washer
Just did my 2023 BRZ's first 1K Mile, 1600 KM, oil change. However, I couldn't find the original crush washer. It is definitely not on the oil pan drain valve. And I asked three people to examine the drain bolt and they all said the crush washer couldn't be on the drain bolt.
I checked the old oil in the my oil pan and it's not there. I poured the old oil into a jug and poured it back to my oil pan, used my hand to feel around and it's not in the old oil. I'm now afraid I have double crush washer the oil drain bolt now. Is it a big deal to double crush washer it if I torque it to spec? I will get a new oil drain bolt from dealer and do my next oil change before winter in 5 months. Should I wait that long if I double crush washer it? Thanks. |
#2 | |
Proud of BOXER
Drives: Subaru Boxer
Not sure if it's the case for the 22-23 but the original twins came from the factory with the black paint OVER the top of the crush gasket. So when you removed the drain plug bolt the first time, the crush gasket stayed stuck to the outside of the pan. I've also seen it stay stuck to the drain bolt itself and have to be pried off of it. Again, due to the black paint getting on it.
It was necessary to gently pry it off there and then replace it when doing the initial change. Could've been what happened here as well. Was the edge area around the pan's drain valve opening smooth to the touch? You would've been able to easily feel if the crush gasket was stuck to the pan. I don't know enough about crush washers to say if having two of them on there will cause a slow leak or not. I'd say put some cardboard under the car and check for signs of leaks in a day or two.
| The Following User Says Thank You to Clipdat For This Useful Post: | Boomerang (05-04-2023) |
ProCrastinationConsultant
to quote the great puddins fab shop, it'll either leak or it won't.
and if it does, we'll say it never should've!
#4 | |
I put back the one day old oil in the BRZ. So I wasted 30 minutes and another crush washer but at least I can sleep better now. |
| The Following User Says Thank You to Maplemoose For This Useful Post: | Clipdat (05-03-2023) |
#5 | |
Proud of BOXER
Attaboy! Glad you got it sorted. Now you can get back to enjoying your BRZ!
| Size of new crush washer for oil change? | Interceptor777 | BRZ Second-Gen (2022+) — General Topics | 3 | 02-06-2022 11:32 PM |
| Crush Washer Sizes | Eric1855 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 55 | 08-30-2021 02:21 AM |
| Crush Washer on Drain Plug? | torql13 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 05-04-2021 07:27 AM |
| OEM Oil Drain Crush Washer Buying Tip | radroach | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-20-2016 09:42 PM |
| Crush Washer for AT | BRZ888 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 07-27-2014 10:06 PM |
